luciens
Geebax Posted at 2017-12-30 18:35
'Both are bad, but one is only the pilot's fault.'
Why do you keep bringing this up, if the aircraft falls out of the sky and hits someone, the outcome is the same, arguing about who was at fault is pointless after the fact. If it damaged anything or anyone, they are still damaged.
Well, another pillar of aviation is: when an accident happens it's crucial to determine what went wrong so you can prevent it from happening again. So it's not only not pointless, but absolutely critical to determine fault in an accident. If it was pilot error by not planning the flight correctly and the battery is exhausted because of that, it's important to determine that so the proper corrective action can be taken. If it was a manufacturer defect, particularly a purposful, but bad, decision to cripple the aircraft in firmware, than that needs to be brought out as well, again so that the corrective action taken is proper. You can't just go "oh well, it's water under the bridge so let's let bygones be bygones", if you want to prevent a repeat of an accident. It just doesn't work that way.
Answer this, if the flyer has lost control of the aircraft and it has drifted into the NFZ, what should happen then?
As you already know, what we do in full scale is get the aircraft on the ground _in a controlled manner and in a proper location_ and make the situation safe _first_. _then_ the army guys come out and put the cuffs on, etc. That still requires _complete control of the aircraft_ to accomplish.
What you do NOT want is the aircraft going _out of control_ and doing who knows what or what someone at DJI decided it should do. That's the antithesis of making the situation safe as quickly as possible - you don't know what's going to happen or where it's going to come down at that point. Unknowns like that are poison in aviation.
so whatever has to be done at that point, human control of the aircraft must be maintained at all times regardless. |
