Crystalsky 4G USB dongle feature = FAKE
123
17893 113 2017-12-27
YOYOMAN
Flight distance : 676260 ft
Réunion
lannes Posted at 2018-2-26 04:31
I remember reading about how you can set up the Huawei as self booting (Modem mode) so that it is immediately recognised by the android OS as a modem instead of usb storage but I can't find the web page anymore
Hi !
Don't you mean when you disable SIM pin it automaticly connects to the 4G Network?
It does with PC, but I still have to select the network through my computer...
Mindy? Mindyyyyy ?? we miss you a lot !! =) hope everything is fine ! Here, the 4G Dongle USB Feature for Crystalsky still doesn t work ! even using the device you told me to buy !
2018-2-28
YOYOMAN
Réunion
Hi !
Is 4G Dongle USB Feature for Crystalsky going to work one day? or it s going to stay a legendary?
2018-3-1
roger39
Maybe, with a next firmware wait and see .
2018-3-1
lannes
Flight distance : 4465 ft
YOYOMAN Posted at 2018-2-28 10:15
Hi !
No, it's some other mode I read about, that lets  you plug and play the Huawei without an app or widget
2018-3-2
YOYOMAN
Réunion
lannes Posted at 2018-3-2 02:43
interesting Iannes ! thanks
I m going to make some research about this !
Still no any DJI support?
If we do not need anything, we ask DJI support?
2018-3-2
lannes
YOYOMAN Posted at 2018-3-2 09:13
Have a look at this
http://www.matrudev.com/post/use-huawei-usb-modem-android-tablet/
2018-3-3
YOYOMAN
Réunion
lannes Posted at 2018-3-3 14:22
Have a look at this
thanks Iannes !
I didn't success =/
Anyway, not support from DJI? this feature is a lie, is not it?!
2018-3-25
YOYOMAN
Réunion
Still no support from DJI for this feature.
2018-3-27
YOYOMAN
Réunion
Any news about this promised feature?!
2018-4-16
Matioupi
Flight distance : 922569 ft
Hello, i just gave a try with my CS (02.06.03.00) and had it working right away.
I'm using a rooted CS with Google Gapps enabled.
The dongle is Huawei with a French network operator
Yes, Wifi is disabled... so i'm sure the internet comes from the dongle.
I hooked the dongle, waited for a few seconds, went to settings / Wireless & Networks / More / Cellular Networks / Network operators / Choose automatically
I got a success registering to ntwork message and that's all...
2018-4-26
YOYOMAN
Réunion
Matioupi Posted at 2018-4-26 05:02
hi !
Thanks for help.
Do you use 3G or 4G? Which exact model of dongle do you use?
I've tried your process but in cellular network settings, everythink is grised.
What do you mean by CS rooted with google Gapps enabled?
thanks
2018-4-26
Matioupi
It a Huawei with USB identification usb vendorid:productid = 12d1:1506 (it's E398 model if I remember correctly) 3G only. I'll try a 4G if I can catch one.
Rooting the device and flashing gapps is explained here with details and I guess easy to follow steps :
https://github.com/Opcodeffm/csroot
https://dji.retroroms.info/howto/crystalsky
Rooting means to get an administrator account to the device
Gapps is basically the Google Play / Google Services that allows you to go to the playstore and link your account.
All this will probably make you loose the warranty on your tablet, but at least it makes life much easier and this stuff usable !
With latest version of Google Play service, you may have an additional step (not yet in the Wiki) After installing, you may have to visit : https://www.google.com/android/uncertified/
to be able to link the device to your account
You'll need a code that you can get with the command line given on the above link though adb, basically a command line tool to access the underlying linux system on an android device, and get the requiered unique id of your machine.
pictures of the setup with Nova Launcher installed instead of this infamous DJI Launcher...
image 1
image 2
2018-4-26
YOYOMAN
Réunion
Matioupi Posted at 2018-4-26 06:34
Thanks a lot for theses informations.
Do you still have access to DJI Pilot app with a rooted CS?
2018-4-26
Matioupi
yes, you have access to everything stock, plus you can install all apps that require play store access, like litchi
2018-4-26
Matioupi
on step you can try first (just in cas) is to activate developper settings on your tablet :
go to settigns, about device and then tap 7 or 8 times on the build number info.
This does not require root or anything else... just to see if it "ungray" the mobile network settings that would let you use your dongle.
2018-4-26
roger39
Hi !
hello,
if you root your tablet crystalsky, no longer call mindy
2018-4-26
YOYOMAN
Réunion
Matioupi Posted at 2018-4-26 22:29
It doesn't ungray unfortunatly.
Anyway, I would like to know if you feel your CS UB warmer or cooler or same? than before rooting operation?
2018-4-27
Matioupi
YOYOMAN Posted at 2018-4-27 09:43
I think it's a little cooler... I disabled a few services, and tuned a few stuff. I never had the "too hot" warning, but I also never used it with very warm outside temps.
Still the fans are turning on a little too often to my taste.
2018-4-27
Rickyber
Flight distance : 403488 ft
lannes Posted at 2018-2-1 17:34
Getting closer, try installing the "google now launcher" from apk pure.
I can now use this as the app launcher page instead of the DJI launcher page.
Thanks so much !!!
Being the fact that you mentioned about Android 5.1, you think for this expensive piece of equipment they would have installed a more up to date version and also a complete version instead of their modified version. Probably has something to do about paying for software licensing and taking the cheap way out to maximize profit margins.
2018-4-27
YOYOMAN
Réunion
DJI Mindy Posted at 2017-12-29 02:45
Hi, currently, only two 4G dongles have been fully tested, that is MS-2131i-8(3G global)and 2372h-153(4G Russia/Europe/The Middle East/Africa).
We do not recommend other dongles without test, thanks for the understanding.
Hi !
Today we are in 2025, phantom 17's just been released with crystalsky 5, but we re still waiting the promised "4G USB Dongle"    I begin very old, I hope DJI ll release this feature before my death...
2018-5-25
djiuser_SGZZVqw1clJJ
Flight distance : 779098 ft
Well you can add this one to the compatible ones on the Crystalsky The Nighthawk® LTE Mobile Hotspot from Netgear on AT&T Just get a long USB-C Cable to tether with, then plug it in before booting and it works great! You can also set the Hotspot to turn off its wifi while on tether and turn off the wifi on the CrystalSky to cut down on all the extra wifi interference.
2018-6-30
Teddywildviking
Norway
2018-8-21
Teddywildviking
Norway
u have to use the specific model of dongle in this video
2018-8-21
Teddywildviking
Norway
2018-8-21
Teddywildviking
Norway
YOYOMAN Posted at 2018-1-1 23:34
Hi DJI Mindy,
I didn't find any information about " 2372h-153".
Could you give me more information: brand, dealer, etc. ?
https://www.amazon.co.uk/Huawei- ... ongle/dp/B0104LV06M
2018-8-21
Bucshot59
Has there been an update to this yet?
2019-5-13
MattMo
Flight distance : 1226608 ft
I tether to my phone. Works a treat.
2019-5-14
Drauzer
Flight distance : 1728602 ft
The  ZTE MF79 Modem works well (connected, rebooted and everything works)     Хорошо работает Модем ZTE MF79 ( подключил перезагрузил и все работает)
2019-9-27
MapperMan
Turkey
hi DJI, still no explination?
2019-12-3
teamadcor
Flight distance : 1061847 ft
"just use smartphone to connect to Internet"
My crystalsky monitor doesn't see my Huawei P20 pro hotspot.  I've use it for many other devices. I'm in Europe and I really need an internet connection for the crystalsky.
I'm using DJI Pilot app for my M200 drone.
What should I do?
DJI please help.
Ps. I set up the hot-spot connection manually without the device recognising my phone. It does see lots of other connections including my home wlan.
2021-2-22
teamadcor
Hi everyone....  I just bought a crystal sky and can't load any maps while on location.  I have a Huawei 20 pro which works as a hotspot for absolutely every device except the CS.
So like an idiot I bought a USB wifi dongle to plug into my CS instead. Of course it doesn't work either.
Just read all the posts and I can't believe this problem hasn't been solved by DJI.   I heard how much better the CS was over a smartphone, but to know that it runs on Android 5.1 is laughable.
Does anyone have a real solution to plug in a E3372 LTE USB stick????
curious to hear your replies!
2021-3-1
Mike Shock
Flight distance : 81385 ft
Russia
With the supported models it should be as simplke as this: https://m.youtube.com/watch?v=v2Eq3dzrd-oUnfortunately DJI never published the official list of supported USB dongles.
2022-1-14
Mike Shock
Russia
roger39 Posted at 2018-2-17 02:21
[view_image]
I bought this dongle from a Chinese site, and I can not use it.
The "recommended" model is Huawei 2372h-153. The Huawei models 3372-320 and 3372-153 a completely different devices (-XXX digits matter!).
2022-1-16
Mike Shock
Russia
I tested the Huawei E3372h-320 (HiLink, firmware version 10.0.3.1, H192SP2C983) 4G dongle.It perfectly works with my CrystalSky CS785 HB, even without reboot.
2022-1-19
123
