fansa84fe8a4
inspirelwdd Posted at 2017-12-29 07:34
Update, after spending a couple hours with the Inspire v1.2 yesterday (12/28/2017), here is what I've determined:
1. Calibrate (for gimbal and GPS). When I open the DJI Go App and choose the button to Calibrate, the app is dead. I cannot Calibrate. I've now come to find that this is telling me the RC and the Inspire are not truly connected. This also means if I ignore the Calibrate and continue, the bird will fly, but I've lost my settings and even if I try to update the Name of the bird in the app itself and press SAVE it doesn't work. That was my first indicator that the app and the bird were not working properly. So, in summary, if I press Calibrate and nothing happens, every setting that I've configured is gone.
Although you are using GO 3 and I'm using GO 4 with the I2, your results mirror mine where the settings are not being saved at times. Even though the RC works for flying and the screens says "Ready to Fly" and green, but it isn't fully ready.
I suspect the two iPads I'm using are dropping the data line somehow, or GO isn't connecting to the USB right and the connection between the iPad and GO isn't right. If I unplug and replug a few times it all links up again. Not a cable issue as I've tried about 6 of them along with a new one from Apple Store.
Sometimes if I close down GO 4 and move to an app like Litchi or Autopilot, those apps will not connect right either. It's as if GO alters the USB port somehow when I shut it off. Could be the iOS SDK that DJI is using to make GO for Apple devices is messed up too - and maybe same for the app makers too. I dunno, but something is wrong somewhere.
