hobbydroner
Belgium
Tviscomi Posted at 2017-12-29 05:23
Not sure why you would want to store edit/finished work back to the SD card it consumes space, most folks store on external device an delete from sd card. With that said, you can remove the card from the Spark, place it into a SD slot on PC/laptop and copy edited files back to the card
yes you are right ,no use put on sd card(space consuming) ,my goal will be to put my work on laptop cause I think the image quality on laptop is far better than on ipad . Thanks for your advice,I appreciate. |
