DJI Phantom 4 Pro just fell out of the sky!
967 7 2017-12-29
Gianluca Vassal
Flight distance : 629747 ft
Malta
I was using my drone today when at the beginning of the flight I got an ultrasonic error, after moving to a different area and restarting the error did not come again. I was then flying it normally when I lost signal, the drone was not far away from me and it was still in sight. I clicked return home and the drone came home and landed normally. I restarted my drone a second time and tried to fly it close to the ground to test flight capabilities, however when it was at 1.5m height, flight was very unstable and after a few seconds the drone just fell from the sky. When I tried restarting it again I was getting gimbal motor overloaded. The drone does not have any physical damage just scratched propellers and a twitching gimbal. Did any of you encounter this problem? Is this because of the recent firmware update?
2017-12-29
BagoDJIoperator
Flight distance : 1077608 ft
Trinidad and Tobago
not sure what happen? can you upload your flight logs and see maybe we can see what caused it.
2017-12-29
DJI Diana
Flight distance : 2408 ft
Sorry for the crash, I would recommend you send the drone in for diagnosis, our support will submit a data analysis to check what happened. Please refer to the link below to contact the Support to start a case first. https://www.dji.com/support?site=brandsite&from=nav
2017-12-30
Gianluca Vassal
Malta
I have sent it for repair and I have also opted for data analysis. I was flying my phantom everyday but since the firmware update it didn't feel the same. It was very strange yesterday that I lost signal  at 330m range in plain sight and I had to restart the drone to regain signal.  It was more bizarre to see it just fall of from the sky!
2017-12-30
AlanHd
Flight distance : 767762 ft
Gianluca Vassal Posted at 2017-12-30 01:29
While you are waiting you could always upload your flight logs for people to have a look at, they may be able to shed some light on what happened, here is a link with the instructions how to do it http://www.phantomhelp.com/LogViewer/Upload/
2017-12-30
Gianluca Vassal
Malta
AlanHd Posted at 2017-12-30 01:55
Hi AlanHD, since I have sent the drone already for repair, is there a way of how to upload the fight logs from the app on the mobile phone. Before sending it off I had synced all the data.
2017-12-30
AlanHd
Gianluca Vassal Posted at 2017-12-30 10:00
The flight logs are on the mobile device, the link I provided gives instructions on how to retrieve them for both android and IOS.
2017-12-30
Gianluca Vassal
Malta
AlanHd Posted at 2017-12-30 10:06
Thank you very much. Will do so!
2017-12-30
