Micro SD card Questions
857 7 2017-12-30
Dhillskiier1653
Flight distance : 391818 ft
So this christmas I got this micro sd card. Would it be good enough to record in 2.7k with my Phantom 3 standard? Here it is:
https://www.amazon.com/PNY-Elite ... EL-GE/dp/B01G26R7M4
2017-12-30
Labroides
Flight distance : 9991457 ft
It's probably fine.
There's one way to tell  ....
2017-12-30
Geebax
It may or may not, but to save yourself a lot of grief, just buy a Sandisk Extreme series card, they always work.
2017-12-30
Kuya Kano
Flight distance : 797913 ft
Philippines
I agree with Geebax.
Sandisk Extreme Pro is the absolute most reliable micro SD card out there.  Nobody likes to get a glitchy video when that perfect filming opportunity arrives.
2017-12-30
Seattle_Steve
This cards write speed is below the ones everyone has recommended for drone video recording on multiple sites.  This card is a UHS type 1.  Here's the best explanation I have found about the difference...
UHS came about due to 4K-capable video devices needing faster write speeds. The SD Association has two UHS Speed Classes, UHS Speed Class 1 and UHS Speed Class 3. UHS Speed Class 1 supports a minimum 10MB/s write speed, whereas UHS Speed Class 3 supports at least 30MB/s write speed.
The Extreme series is type 3 but the Extreme Pro is the fastest most reliable. Extreme Plus while not recommended is reasonably price type 3.
2017-12-30
sky wombat
Flight distance : 1454078 ft
Kuya Kano Posted at 2017-12-30 18:50
Guess whose card generated the card full warning? Then I couldn't delete the videos. After contemplating my navel for a while worked out I had locked the adapter. Hmm it's been a long year.
2017-12-31
A CW
Flight distance : 13838848 ft
Being a U1 it's questionable - should of got a U3 to be safe
2017-12-31
Rvrrat14
Flight distance : 655932 ft
Been wondering this myself.   The Phantom 4 User Manual states;
Micro SD, Max Capacity: 128GB. Write speed ≥15MB/s, class 10 or UHS- 1 rating required
Does this mean anything higher than UHS-1 is acceptable?  Thanks.
2017-12-31
