JensIR
Flight distance : 207631 ft
Norway
Yesterday my Mavic just died mid-air and dropped to the ground. I am trying to analyze what happened, and so far this has been a frustrating experience.
Some background first:
I own a Mavic and a Spark. I have owned the Mavic since early December. I am not an extremely experienced drone pilot, but I do have previous extensive experience with radio controlled aircraft of different types over several decades. Up until yesterday the Mavic had performed flawlessly (more than can be said about the Spark). I have an estimated 3 hours of flying the Mavic accumulated during December, without any issues whatsoever (until yesterday).
The incident:
Took the Mavic out yesterday for some short test flights. Temperature was around +5 C, wind was low. Surroundings rural with few sources of interference. Aircraft, controller and app all at latest versions.
When I powered it up I noticed that I had forgotten to put back the SD card in the card slot since extracting some videos a few days before, so there would be no video/photo recordings. I still wanted to make some short flights to get some more practice flying it realtively low and nearby.
I took off and went up to an estimated 5 meters altitude and proceeded to fly a small circle before slowly flying a bit further away. After around one minute the Mavic was an estimated 40-50 meters away, still at around 5 meteres above take off level, flying out over a small valley. Then, without any warning the aircraft just shut down and dropped to the ground, it all happened in what seemed like a split second. The terrain at the incident position was lower than the take off point, so even if I was just 5 meters above the take off level the Mavic dropped an estimated 10 meters into a rough grassland with grass and plants and a little bit of wet snow.
Immediately after this happened I looked at the DJI GO screen and it said "aircraft disconnected". When I proceeded to move towards the accident point I could suddenly hear the motors of the Mavic engaging for a spilt second and on the DJI GO screen the "aircraft disconnected" message had disappeared and the video feed from the Mavic seemd to be restored, now showing of course only grass and snow.
After locating the aircraft and inspecting it I found it to suffer from two slightly chipped propellers, a slightly cracked right front landing gear leg and a dislocated camera gimbal (the gimbal issue was not found immediately).
After spending a long time researching how to analyze this incident I seem to have found two types of logs:
As I understand it there is a .txt file on the controller tablet. I have located this file and uploaded it here: http://www.phantomhelp.com/logviewer/BKZO7D7A6VSE62R1RSGS/
As far as I can tell it does not give much useful information other than to confirm that the aircraft just stopped transmitting after approximately one minute, which is the exact time it must have "died".
Then I have tried extracting the so-called .DAT files as decribed for example here: https://datfile.net/DatCon/retrieveV3Dat.html
This is where I am having severe issues even locating the correct file. The files listed by the DJI Assistant software seems to have dates and times that have no relation to the dates and times of my actual flights. Even after extracting all files list by the software and unpacking them with the DJI extract utility I am unable to locate any logs of most of the flights I have made with the Mavic in December. I can find some logs, but from the time and dates and contents listed in CsvView they seem mostly to be related to times when I have powered up the Mavic indoors to check configurations, change settings and in general famliarize myself with the interface of the app. The logs of the actual flights seems to be missing as far as I can tell.
I was able to locate one log that may be from the fatal flight, but the time listed does not fit completely,and CsvView say there is no GPS data in that log so I am not able to confirm anytihng. From the time stamp it may be from a short test flight I made after the accident, after replacing the props and inspecting the aircraft. This flight was aborted quickly due to exessive camera vibrations due to a dislocated gimbal (I have since been able to fix that).
Right now I am not able to make any more test flights, due to weather conditions and short daylight hours, and I am not sure I will have time to do so for quite some days to come. In any case it is not tempting to fly the Mavic again until I have some more information about what happened, knowing that it can potentially drop out of the sky at any moment. During next weekend I may go back to the location where I have flown the Mavic during christmas, where there are areas of deep soft snow, which will greatly increase the chances of survival if this unexpected shutdown happens again.
And as noted, I am at the moment at a loss about what to do due to the appearent missing log files (or maybe I am just doing someting wrong).
Any kind of input from experienced Mavic users will be highly appreciated.
And sorry for the long first post, hope someone has the patience to read it all.
