Grmachine
paulyp99 Posted at 2018-1-5 15:33
Is there any way to fly the spark with controller navigating forward and reverse as seen by controller, not aircraft. Meaning when I fly forward away from me I push the controller stick forward. If I turn the spark around where it is facing me then in order to go forward I need to pull the control toward me. Is there anyway regardless of the direction the spark is facing to use the controller and push it forward to make the spark go farther way or pull the controller towards you to make it come back?
That is known as headless, its found on most of the toy drones.
I've been a Radio Control hobbiest for many years, using the simulator mode to practice, will help a lot with getting used to flying towards you, its a very good tool for flight practice. |
