JM-Drone
Flight distance : 7434 ft
Malaysia
Hi DirkGerrit, first of all, there are few 'Flight Modes' for your Spark, which are: Standard, Sport, & ATTI (Attitude)
ATTI Mode is short for Attitude Mode (without GPS, i.e.: for indoor flight), where the drone will maintain a specific altitude but not position (as the position won´t be stabilised using GPS). That means the drone will remain at the same height but drift around in the wind. It also means that there is no auto-braking when you are flying, so the drone will continue moving in the direction you are flying until you push the stick in the opposite direction to brake.
From my experience, there are few scenarios that your Spark may suddenly switch to ATTI in the mid-flight:- When you are indoor (obviously)
- If you do not wait for the GPS to be fully active (ie. not enough satellites found)
- Your drone entered to a place with magnetic interference
In my own opinion (if I'm wrong pls correct me), always 'playsafe' and do these before flying...
- Always calibrate your compass before flying at a new location
- Always wait for GPS to be fully active and detect as many satelites as possible (when it says "Ready to Go GPS")
- Always wait for Spark to save its 'home' position before start flying around, and use the 'RTH (Return to Home)' button to double check it able to initiate RTH correctly / automatically when it is out of control.
- Always slowly flying near you to check if there's any magnetic interference nearby before flying farther / higher
Anyway, I'm just a beginner in using my Spark, hopefully some other more experience users will add more input here. Thanks and have a fun flight
