helmarw
Flight distance : 12730 ft
maybe you should read everything, not only the parts which supports your false claims
3. Check whether your product must be tested by a Notified Body
For some products, special conformity assessment bodies ('Notified Bodies') must verify that your product meets the specific technical requirements. This is not obligatory for all products. Use the "Nando" database to identify which Notified Body to contact in your case.
( dont have time to waste checking the databaese, but im pretty sure all RF emitting devices have to be tested by a notified body!)
4. Test your product
If your product doesn't need to be verified by an independent body, then it is up to you to check that it complies with the technical requirements. This includes estimating and documenting the possible risks when using your product.
(those test can be done by the manufacturer, if he is ISO certified and has the appropriate expertise, of course it needs to be documented, alternatively there are companies which can do that for you, usually the batter choise)
5. Compile the technical dossier
Your technical dossier should include all the documents that prove that your product complies with the technical requirements.
6. Affix the CE marking and draft a declaration of conformity
Finally you can affix the CE marking on your product. The marking must be visible, legible and indelible. If you had to involve a notified body in step 3, you should also put the identification number of this body on the product. You must also draft and sign an EU declaration of conformity stating that your product meets all legal requirements.
In Sparks CE report it states:
The notified body, Bay Area Compliance Laboratories Corp.(BACL), notified body number: 1313,
performed the EU-type examination in according with Annex III, Module B of Council Directive
2014/53/EU, and issued the EU-type examination certificate: B1703213
So yes they used a notified body and did not just fill it out them selfes.
never the less i agree that as the product's manufacturer, you bear sole responsibility for declaring conformity with all requirements.
I never disputed that.
But Its always a good practice no matter if you require it or not to get your product tested by a notified body. DJI did that, so my question is still what do you expect to achieve here ?!
should DJI pull it of the market, disable 5.8GHz ?!
if Spark is in violation with the law, you should not use it and if you own it you should destroy it immediately!
