Mickus
Flight distance : 601677 ft
endotherm Posted at 2018-2-20 04:39
I took the comments to be some light-hearted ribbing. Most of us are keen to help when someone indicates they've had a crash, so I assume they were just eager to view the record.
If you want to see what the aircraft was doing, and to get help from the forum, you really need to extract the flight log from the smart device, then upload it to PhantomHelp as indicated previously. This will lay out in minute detail what each sensor was recording and what controls were operated etc. Pretty sure this is what you were asking for in your original post. If you share the link here, many of the experienced people here can interpret it and give you their informed opinion, otherwise we only have your version of events and description to try and determine what happened. Usually that is far from adequate, especially if the cause is something unintentional or subconscious such as nudging the stick accidentally. You can upload the log quite independently of having sent the aircraft to DJI -- the log is in your device and any discussion on the forum won't influence DJI's examination or decision. There is a much more detailed log inside the aircraft which DJI will examine, but it is typically way more detailed than needed, especially when we have the simpler flight record at hand. To view the internal "black box", you attach the aircraft to a computer via USB and access it like an external hard disk. You extract the relevant DAT file and decrypt it with 3rd party software like DatCon. Be aware it will contain a lot of confusing technical data, much of which won't help you at all. 99.9% of cases rely on the simpler flight data we upload to Phantom Help.
Meneva17, I would take what Endotherm says, and others have advised, upload the log. It is simple to do and I can assure you that Endotherm will give you a good analysis of the data, and you will get a better understanding of what happened and why. I was in the same position earlier this week and by uploading the log I got an excellent analysis of what occured during my crash. I dont think the forum has any interest in mocking anyone, my experience is that the people posting here are willing to share knowledge and experience if you let them. In the end it does not really matter much if the crash was electro/mechanical/weather or pilot error, what is important is you gain the understanding of what went wrong. I wish you luck. |
