Genghis9
![](https://forum44.djicdn.com/data/attachment/common/9b/common_15_usergroup_icon.png) First Officer
OK got it...
My suggestion is make a test flight, close in low altitude. If she flies without problem and no issues then expand your following flights. If after a few flights you have no problems, then leave it alone it is good to go.
IF on the other hand you would prefer to update the bird but you are unsure or if you do have problems that require updating, then make another Post that has a title more to the point like Should I update my P3P. List the same data noted above and with that you'll get a lot more opinions about the topic. My suspicions are your title for this thread is not getting others to take notice, either that or change the title of this post. I think starting clean would be better. |
