DJT_MVSP
Flight distance : 2018645 ft
Singapore
fans61e5664e Posted at 2018-1-9 01:24
So does that mean every time you check the battery status (assume that is clicking the power button to see the leds light up) the 10 days reset from there? So if you clicked on the 9th day, it would revert back to discharging 10 days from then? Sorry for my lack of knowledge.
Yes, you are 100% correct.
It will start discharging exactly on the 10th day of idling. It takes around two days to discharge to below 70%, so if you press the power button while it's discharging, it will stop discharging and will start the 10 day countdown again for the next auto discharge.
It won't discharge if the battery is lower than 65% |
