LIVNXXL
Flight distance : 1806125 ft
LIVNXXL Posted at 2018-1-12 08:25
I guess I could have added more detail yet. Cable between controller and Ipad new and certified. Even used original cable that came with the Ipad till I was tired of the hanging length. Cable between vibration board is new on I1 V1. I have a parts drone and even changed the compass unit ( internal component the the vibration board plugs into) I do live near and often fly in the New Jersey Pine Barrens which are famous for bog iron so location could have been a good culprit except I had the same issue in Palm Dessert CA, Park City Utah, Mont Tremblant, Quebec. Some of the locations are populated and some so remote there is no cell signal. Green screen varies and is unpredictable. Temps have varied from 114 down to -23. Definite on the GoApp for I1 and not I2. Litchi works like a dream so I will keep switching back to the as DJI updates it , as well as keep trying along with Apple updates. It may be an Apple IOS issue, Who knows. I am still in the air and still having fun. Its electronics and crap happens. I, We, the forum will get it resolved. In the meantime I am still having fun and hope this helps others. Still cant get 32 channel Upgrade to take. Going to try again later.
Thanks again, I will follow up if anything changes
Lets talk about changes over a very short period. I have no clue how this relates but it might spark an idea and help someone else. If you follow my post in this thread you will see I had some weird lag/green screen issues when using DJI GO app. When using Litchi all was good. I was out flying/testing both Inspires on the 13th using Litchi app. The I1 V2 started giving me a message of "MC not connected to mainboard". It switched to Atti mode and I immediately brought it in and landed. Time to pack up and go home. I started a repair ticket and will be sending in the Inspire to the New York repair center. This is where it gets odd. I was having the same issue of lag and green screen on both Inspires sharing the same Ipad. After starting the repair ticket I factory reset the Ipad and started as a new device. I went out on the 14th with the Inspire 1 and my Mavic. Using the Ipad with DJI GO and GO 4 everything was perfect. I have no explanation why both were showing the same problem and yet only one had an issue. The DJI go app recognizes each INspire individually so I don't think settings or memory could be in conflict. I will follow up with what needs to be fixed on the I1 V2 once the estimate is sent. Donnie, Thanks again for you efforts as well as everyone else who tried to help. Makes no sense to me but I have a flyable Inspire again. |
