DJI GO 4 app - Network unavailable. Chcek your internet connectio...
7540 12 2018-1-12
taox.taox
Flight distance : 20085 ft
Czechia
Hello. I have probably old Samsung Galaxy S4 with android 5.0.1
If i try to login in DJI GO 4 app - the phone write to me "Network unavailable. Chcek your internet connection"
But i have internet on the phone OK. This not work on the wifi or on the mobile data too.
As i understand i can fly without login. Is very frustrating. Tomorow i should fly on the world trip and drone is dead. The problem is in phone or in apliaction?
2018-1-12
hallmark007
Flight distance : 12400594 ft
You must be logged in to app to fly, you only have to login in once after that you should be ok to fly.
2018-1-12
taox.taox
Czechia
Thank you so much for the reply. But us i understand i can use the same login like for this forum...if u use it - it does not work. I can NOT realize my first login in to the aplication. It write me:"  "Network unavailable. Chcek your internet connection" but everythink is OK. It looks like the aplication does not recognize that the phone has already internet connection....
2018-1-12
djiuser_o9C3JDs
Flight distance : 17136 ft
Sweden
Hi
I have exactly the same problem. I purchased the SPARK today to do some investigative work but still can't use it. After starting the DJI GO 4, all setup work fine. I have also upgraded both the Drone and Remote to the latest versions. Everything goes fine up until its time to Activate. The the same problem occur as above.
I have both tried to create a new login as well as use my current login. Neither work. Same fault message. I have tried to force the app to use 4G data but the error remain. It's like the app simply refuse to use Internet. If I log into the remote, it take awhile longer before the error occur or it simply refuse to proceed (which is logical in a way). I have also tried switching back and forth between the Wifi connections (Internet and remote) but then it just stay on "login" and refuse to continue. In that case I have to go back to the previous login page, re-enter my login name (and the 4 character which is very annoying) and either select a password and use my current one however, as soon as I click login, the same error message occur "Network unavailable. Check your internet connection" even though I have a perfect Wifi connection and Internet.
I have also reinstalled DJI GO 4 twice without any look. I have also tried to roll back the DJI app to an older version however, then the Spark is not recognized.
Please help!
2018-1-12
hallmark007
taox.taox Posted at 2018-1-12 13:54
I’ve also read another guy from Bulgaria over on phantom forum same problem, just wonder is server down , maybe a mod can clear this up.
2018-1-12
hallmark007
djiuser_o9C3JDs Posted at 2018-1-12 15:13
Hi
Check out this link looks like server is down.
https://forum.dji.com/forum.php? ... &fromuid=260008
2018-1-12
Czyżol
Flight distance : 18907 ft
Poland
In Poland, the same problem.
2018-1-12
taox.taox
Czechia
Now in the DJI company.....
2018-1-12
DJI Diana
Flight distance : 2408 ft
Hi all, there was a server glitch, but it has been fixed now, please try to log in again, it should work now, sorry for the trouble you all have been caused.
2018-1-13
taox.taox
Czechia
Hi. Thank you so much !!!
My solution for odler phone Samsung Galaxy S4 with 5.0 android was:
- Google store gives me only the DJI GO 4.1.18 aplication > it has trouble with connection
- I download the DJI GO 4.1.22 apk from www.apkmirror.com and instal this version
- This version has no problem with the connection on DJI servers and works fine on the older phone...
2018-1-13
hallmark007
LMAO great picture.
2018-1-13
djiuser_o9C3JDs
Sweden
I have tried with my old Samsung NOTE3 and it also work fine now. Everything is hunky dory and I will go fly tomorrow!
2018-1-13
fans76555169
Bosnia and Herzegovina
Same problem today. I can not log into the DJI GO 4 app. Network Unavailable error.
Very frustrating.
2020-11-8
