Spark battery fell out during flight
12Next >
17890 78 2018-1-22
mmhamzeh
Flight distance : 6831 ft
Indonesia
I just watched the battery of my Spark drone fall out over the ocean.  The drone plunged immediately after.  The battery sank immediately. The drone floated but was swiftly carried away by the current. I was using a controller and the DJI app on my iPhone.  This seems to be a common defect.  It is a new drone that had less than a dozen flights. What are my options?
I purchased the drone from a Apple store.
2018-1-22
Malakai_UK
Flight distance : 536115 ft
This is exactly whats worrying me. There are more and more sparks having the battery pop out. I'm guessing your battery was one of the early models where the little catch wears out. The newer ones have larger catches. DJI should offer a replacement program before someone gets hurt because of a falling spark. This same issue nearly killed of the first generation GoPro Karma. However DJI suggest you wait until an accident occurs, then open a case and they will investigate. Why dont they just repair/replace the batteries that have this defect.
2018-1-22
DJI Elektra
Sir, sorry for the accident. Please contact our support and start a case: http://www.dji.com/support. Please provide the filght records to our support and locate the problem. And please provide us the case number  so we can follow your case. Thanks for your support.
2018-1-22
lannes
Flight distance : 4465 ft
Everyone needs to use the battery clip as a precaution, it's quick, easy to install and it's cheap
2018-1-22
mmhamzeh
Indonesia
lannes Posted at 2018-1-22 03:23
[view_image]
Would have gladly used a clip had I known this is an issue.
2018-1-22
mmhamzeh
Indonesia
DJI Elektra Posted at 2018-1-22 03:19
Thank you Elekra. I will.
2018-1-22
Malakai_UK
[view_image]
We shouldn't have to use a third party part to fix an issue that DJI should be resolving.
2018-1-22
A CW
Flight distance : 13877205 ft
[view_image]
That looks like an essential accessory... Thanks for sharing
2018-1-22
lannes
A CW Posted at 2018-1-22 03:37
kinda  cheap on ebay, may be not
https://www.ebay.co.uk/itm/Anti- ... :g:GtcAAOSwokJaYZ0j
2018-1-22
lannes
Malakai_UK Posted at 2018-1-22 03:37
I think we will be waiting a month of sundays for DJI to ever make a product recall.
You either buy a cheap clip or you roll the dice and fly without one.
2018-1-22
A CW
lannes Posted at 2018-1-22 03:47
https://www.ebay.co.uk/itm/Anti-slip-Lock-Straps-Clip-For-DJI-Spark-RC-Drone-1x-Battery-Bundle-Fastener/332525552658?epid=20013378329&hash=item4d6c114412:g:GtcAAOSwokJaYZ0j
A fiver to stop a battery from falling out and losing a £400 drone. I'd say thats cheap LOL
2018-1-22
Malakai_UK
lannes Posted at 2018-1-22 03:49
They only need to replace the catches on batteries that have the smaller catch. I would happily ship my batteries to them for them to replace/repair the catches.
2018-1-22
Tviscomi
Flight distance : 106886 ft
The is the first time I've seen this clip...good find!
2018-1-22
Raploc
Flight distance : 22598 ft
Malakai_UK Posted at 2018-1-22 03:55
Is side by side comparison? I would really like to check my batteries.
2018-1-22
djiuser_UVPq80r
Flight distance : 452379 ft
A CW Posted at 2018-1-22 03:55
If your battery loses connection and slipped out of its click..
Having this battery clip to prevent it from completely falling out of the drone isn't going to save the drone from falling out of the sky.
Worthless imo.
2018-1-22
A CW
Well, don’t judge until you have at least tried I say. Nice to know there are alternatives out there for the individual to decide what they think is best for them to protect their property...
2018-1-22
Malakai_UK
Raploc Posted at 2018-1-22 04:04
First post
2018-1-22
mmhamzeh
Indonesia
I concur that a known issue must be addressed by DJI. Customer support was very responsive. The opened a case and asked me to sync my flight data with their server which I did. the log is actually very cool as it shows the satellite image together with the flight trajectory, velocities and other measurements. I'll update this post with the case outcome.  Being risk averse, in the future I will use every tool available to secure my drone. One cannot be careful enough. And yes, there may still be other ways an accident may occur.
2018-1-22
nixuspix
Flight distance : 2864974 ft
Maldives
I have bought battery clip, but then i can't use prop guards
2018-1-22
lannes
nixuspix Posted at 2018-1-22 05:46
You don't need the clip on if your flying inside
2018-1-22
lannes
djiuser_UVPq80r Posted at 2018-1-22 04:42
The clip is very tight, it can only go on if you have seated the battery correctly and it will stop it from moving, it is just a bit of insurance
2018-1-22
AdamTheGreat
Flight distance : 56991 ft
Especially since that clip scratches the arms on the drone. I double checked my three batteries, they all have the new retention clips (thank goodness). My manufacture dates are 12/17 for two and 10/17 for one. I think anything with a manufacture date before 10/17 has the "old" retention clips.
2018-1-22
Aratheba_Spark
Flight distance : 1779678 ft
AdamTheGreat Posted at 2018-1-22 06:48
Are you sure about that? How can I check it for sure whether I have old latches? Both my batteries are.from 07/17
2018-1-22
AdamTheGreat
Aratheba_Spark Posted at 2018-1-22 06:55
Here is a recent thread that shows the difference in the clips.
https://forum.dji.com/thread-128738-1-5.html
2018-1-22
DJI Elektra
mmhamzeh Posted at 2018-1-22 03:34
You are welcome. Please keep us updated, thanks.
2018-1-22
patrickbateman
DJI Elektra Posted at 2018-1-22 23:32
Hi Elektra, Thanks very much for your guidance here. The same exact thing happened to me on a recent flight. The battery fell out mid flight and my Spark crashed sustaining damage mainly to the camera and under side. I ensured the battery was securely inserted before the flight - I can assume that my model was an early model that is affected by this defect. Per your instructions, I have opened a case and received a shipping label to send the drone back and sent you the case number as a private message. Will DJI cover the cost of fixing and shipping?
2018-4-17
Flighty
Flight distance : 1977175 ft
Croatia
My batteries were from 7/17,, and yes one fell out and the Drone crashed,,, fortunately this was repaired and battery replaced by Dji. Now all my batteries are post 10/17 with the larger retention clips..
2018-4-17
Spruce
Flight distance : 146952 ft
Poland
Flighty Posted at 2018-4-17 11:21
Where can you find the manufacture date on the battery?
2018-4-17
Flighty
Croatia
Spruce Posted at 2018-4-17 11:48
Not sure where to find this info,, however I bought my Spark and batteries in July 2017, after the incident I bought two more in November which had the bigger retention clips.. The two batteries I purchased in July with the small clips have been discarded..
2018-4-17
koumi
Flight distance : 3612 ft
Greece
I have a spark that has less than 10 flights. After 5 mins of a clear flight ( not out of range, no wind etc) and while i have started to land my drone then suddenly the battery popped out and the drone crashed on the ground. I was capturing a video  while this happened and  while drone was on landing process the video stops unexpected. Apparently the battery is fully damaged and the drone has many scratches and apparently I am not sure if it is capable to fly with safety any more. I raised a support/repair ticket  since the drone is quite new ( it was bought on 26 June 2018!!!!!!)  but they need a the whole aircraft for a full investigation although i have sent the video as well as the flight records. Anyways, i have ordered this https://www.ebay.co.uk/itm/1x-Ba ... 2060353.m2749.l2649 (i found on another similar thread in this forum).
Just putting my bad experience with that drone.
2018-7-17
m1n1s
Flight distance : 319915 ft
you can also 3D print a battery clip for the spark , there are a few available on the main 3D printing websites , i never fly without one and i totally agree DJI should issue a clip to all of there Spark owners , the design is very poor
2018-7-17
Marcusc42
I bought my spark in March 2018 at DJI store and found that 2 batteries occasionally have gone to hibernate mode and I got a replacement by DJI in July. I then used my new battery (made in June 2018) and flew it 2 days ago. It flew for 40 secs then I saw the battery pop out and the drone dropped in a forest!! I have searched for 2 days in the forest and still cannot find it. It seems it is a manufacturing fault of the catch. Now I realized many other spark owners have the similar case. Why DJI didn't warn the spark user or provide an additional clip on the battery! Now, what should I do? Is DJI going to compensate my drone and the battery?
2018-8-11
Warriewoodlad
Flight distance : 625230 ft
I got my Spark less than a month ago. When my battery clicks in, it is quite difficult to operate the black slides to get it out. Since I have only one battery, I've decided to leave it in there as a precaution. When I get more batteries, the information above will be quite useful.
2018-8-11
Carmenvail
Flight distance : 1521201 ft
[view_image]
i use this all the time
2018-8-11
Alexey Batalov
Flight distance : 21105262 ft
Battery clip on every flight obligatory for me!!! Gives me a piece of mind and the spark looks kinda cool with it.
Safe Flying
2018-8-13
Northwood
Flight distance : 2148596 ft
Never leave home without it attached.  As someone already pointed out, a very small price to pay for peace of mind, even if you have the newer batteries. (I do).  Weight is negligible.
2018-8-13
fansffbcd0c0
Flight distance : 702 ft
RE: Spark battery fell out during flight
Thank you Electra, I have already contacted support. Spark is on the way to you for diagnostic.
Thank you.
Rc flyer.
2018-9-13
Jakab Gipsz
Hungary
m1n1s Posted at 2018-7-17 04:24
My own printed clip:
From 98m  high fell out my Spark and survived fortunately. I use this clip always.
2018-9-13
Tentoes
Flight distance : 6018255 ft
Hmm. I check that the battery is firmly clicked in. Payday is Saturday and I'll get one of those clips. Can't now, negative balance.
2018-9-13
fanse3890f3b
Flight distance : 16129 ft
I just had it happen to me at 265 ft. :/ My spark will be at DJI on Monday. Did they cover the cost of the repair and replacement battery or did you have to pay some thing. My batteries (2) were made in 07/17.
2018-9-14
12Next >
