Mikolaj
Flight distance : 108471 ft
Poland
The issue is with the wording. DJI Mindy said:
"It may not be described in the release note but we do have optimized the issue."
"Optimized" is the key. Not resolved but optimised, that means minimized the impact as good as they could. In fact, what was most probably done in one of the previous versions was disabling so called cinematic video stabilisation, which is different from optical image stabilisation. The 1st one can be disabled programatically, the 2nd one cannot.
Filmic Pro is not a solution, unfortunately, as it is able only to disable the same. This of course helps a bit, but the actual problem still persists since the very beginning. That's why, the corresponding topic for Osmo Mobile 1 is so long.
I'm sure, that once the new device will be widely available, we will see a lot of reviews. Then we will be able to see, if anything was done about this in the new Osmo Mobile revision. |
