Kloo Gee
Flight distance : 16783757 ft
This is a tough one. I hope you get it back like you did the last one so you can find out what happened.
As it is, with the log file you've uploaded, there just isn't a lot to go on as the others have said. Do you have the cached video you can upload to see if there are any potential clues? I think in your last one, you could see the video tweaked at the last moment showing that it looked like something out of the ordinary happened.
As it is, it is hard to tell if it just lost signal or if it suddenly lost power and fell out of the sky like your last one. Have you tried canvassing the neighborhood in the area (and direction) it was headed? At around 2800' out and 376' up, that is only a roughly 7-8 degree angle. With the trees and houses of the neighborhood of the home point, it isn't out of the question that the AC went out of direct line of site and would lose signal. However, if it just lost signal, then the question is why din't it do an RTH?
