johnyj
Sweden
Same problem here, I bought spark in 2018/5 and only used once, then occupied by other matters abroad, and then came crona for lockdown in another country for 1 year, now that I need to fire up the spark, I found out this 2 led blink 4 times problem as many others had.
Someone said that he took apart the battery but find out the charging on batteries are still ok, so this seems to be a problem with the charge controller board in battery. Somehow it entered a strange state
(update one day later)
I put a current meter in between, I can see that with 5V adapter, the charging current is 0.25A, and with 12V dji QC adapter, the charging current is 0.16A, both are about 1/10 of the normal current. So some current is still feed into the battery/aircraft when this 2 light blinking 4 times circle going on, just don't know if that small current is able to slowly bring back the battery to normal. I guess, if the voltage of one cell is too much away from the other two (typically V of a bad cell raises quickly under any charge), then the balancer might not work, which gives this error
Maybe this 2 LED bink 4 times signal just indicate that system is in low charging current mode, it could continue until the end of the charging process, so that all the cells top around 4.2 volt. However, if a battery like that have slightest drain, then voltage of the bad cell will drop immediately, causing the battery to fail during the flight, better to trash it |
low current charging
