Aardvark
Flight distance : 384432 ft
Nicmaq Posted at 2018-3-3 09:40
It is not acceptable that head tracking does not work as advertized. Up and down is ok. Left right does not work. My understanding is that it won’t work as it’s a limitation of the hardware.
This plus the fact that we can’t have the phone and the goggles at the same time make me think DJI makes false claims when it says they are compatible with the Mavic Air.
They are compatible but you lose all the features that DJI uses for the goggles’ promotion. The fact that no review points this out makes me think that there are a lot of paid reviews. Pretty disappointed.
I don't have the Mavic Air, but similar rules apply to my P4. The head tracking left right of the gimbal I believe is the limitation on all but the Mavic Pro, where the gimbal can yaw 30 degrees left/right of centre. However head tracking flight control should work, when hovering you would have full 360 degree rotation of aircraft/camera, and vertical movement.
They are compatible with all, the different functionality for each aircraft type is listed in the Goggles manual. They certainly lose most of the intelligent mode choices (At least for now) that the Mavic Pro enjoys.
The one single main benefit with the goggles is having a clear image of FPV, much better than trying to squint at a screen in bright sunlight trying to line up a shot or read instructions/warning messages.
They really provide quite an immersive view, focus adjust would be nice, but they work comfortably well for me with reading glasses (prescription for me, set for reading distance of 9.5 inches for good focus). Ideally for most would be an opportunity to try before you buy.
