fans421ca02a
Flight distance : 178773 ft
Labroides Posted at 2018-1-23 17:11
That's just the precision you can expect with consumer GPS.
Try 10 RTH landings and you'll see you get a range of points.
Most will be within 3 metres, many even closer and occasionally you could get some even further out.
Before last years FW update that caused all the trouble my Phantom 4 Always was spot on when landing. Also my Mavic has never missed the circle target when RTH. My son's Mavic also is spot on every time when using the circle target. Now granted, the target cicle is about 1 1/2 meter so there is a little leway but I would always expect it to return to the circle and so far, with the Mavics at least that's what happens. |
