szyrek
Poland
jfredrickson Posted at 2018-2-6 08:39
When I enter camera view it doesn't show anything on the screen. My phone is connected to the controller but the controller is not connected to the drone. That's the problem. I can't connect the controller to the drone or reset the drone so that I can connect directly to it via wifi.
Hello jfredrickson, I have same exact issue as you did back in feb. I hope you were able to get back flying soon. Could you please kindly PM me with support case number, ID or whatever which I could refer back to them? I guess I will have to send it back to DJI for repair too and I'm sure this could help speeding things up a bit on their end, as whatever happened to your bird seems to be same exact thing that now affects mine (at least from all the symptoms mentioned in this thread, they all do exactly match up).
From additional things i noticed (other than everything jfredrickson already said)- it doesn't turn off same way it did before. After normal turn off process it pauses for a moment, blinks last battery led for a few times (for about 2-3 seconds), then signal LEDs on drone go solid red for a moment and THEN it finally turns off. Also in my case it wasn't completly new battery, I actually already used it and flied on it before. When it happened I just flied on one battery- good flight btw, nothing special certainly no damage- then landed (gently, also nothing special there), swapped battery for a second flight- and since then no linking, no resetting anything (exact behaviour mentioned by jdrefrickson, diodes on battery all just blink continuosly when i press no beeps whatsoever). |
