dyVinter
Johny5610 Posted at 5-31 07:11
Hi All, greetings from a rather grey rainy Johannesburg, South Africa. I have just joined the forum and this is my first post. I had a problem running the Go 4 app on my Samsung Galaxy S5, in that the Histogram would not load. When I went into the camera settings and changed the slider to "On", as soon as I closed the settings menu, the slider moved back to the original position. The same applied to the "AFC" slider, which is turned on by default and the "Overexposure Warning" slider, which is turned off by default. Having searched for a solution on the various forums, I found quite a few threads in both the Mavic and Phantom forums but was unable to find any solution...…. and so I persisted in the app experimenting to see if I could find a way to get them to hold their position..... then suddenly the Histogram popped up. I realised that if I tapped on the slider instead of sliding it, the button would move to and hold its new position. It worked on all three sliders. Just thought I would share this in case there are still others out there battling with the same problem.
Hi Johny5610,
Thanks for your tip, it actually works with "tap on it, instead of push" have also tried long, until I have read your tip |
