Histogram not working
12
6397 63 2018-1-25
Shoot It WA
Flight distance : 3576476 ft
I was hoping the latest update on my CS would fix it but I'm having the same problem. Minimising the map and flicking the histogram option from on to off then on again makes it come back.
2018-2-13
djiuser_rJ81o1ep4MXC
I'm experiencing the same issues. Spent about 15 minutes on the phone talking to a tech associate and was no help. I told him I took several steps to try to solve the issue. I downgraded to older versions of the firmware on the mavic. No luck. He had me running circles doing the same thing. I also re-installed the App on my phone. No luck. If i cleared the cache/data for the app on the phone and reinstall, it works if I stay on the screen, but as soon as I close out of the app and connect back, the histogram disappears. From there, I can't turn it back on at all. Hoping DJI fixes this before my trip in a few weeks.
2018-3-2
cirwin1
I am having the same problem with P4P+ after latest firmware update.  Bought unit directly from DJI.  I does not appear that I can roll back the firmware to an earlier version using the latest DJI Assistant 2.  It only allows me to reset to original factory settings, but when I do, all the camera settings remain the same as I had previously set up, so I'm not sure that it made any change.  I did have to turn on the WIFI and reset the password so I could log in, so something changed.  Still not able to turn on the histogram or some of the other camera settings.
I would like to go back to the previous firmware version.  Can someone tell me how?  Will the Beta update solve this problem?
2018-3-4
Drogo2
cirwin1 Posted at 2018-3-4 16:42
Well that is very interesting as the P4P+ has its own DJI supplied device so definitely not an issue there. Seems DJI need to get this software glitch sorted. I still have no overexposure warning (zebras) even after upgrading my device from a Samsung Galaxy S5 to an Nvidia  K1 shield. It will be interesting wht DJI have to say about it.
2018-3-4
superjk
same problem on the Sony Xperia phone
2018-3-7
fans8e1fcfad
Flight distance : 115755 ft
When you "select" it on the menu, do not simply slide it.  Poke the slider to move it.  I just spent a day figuring this out.
2018-3-15
fansf65df67c
Flight distance : 1251453 ft
fans8e1fcfad Posted at 2018-3-15 15:21
I don't believe it but that actually works! This has been bugging me for weeks. Don't slide, poke
2018-3-19
Drogo2
Unreal. That actually works! Thanks for posting the solutionn although how on earth you figured that out I have no idea. Makes you wonder how  anyone  could  fly one of these mchines without the forum to provide answers as  that is a totally  unintuitive solution...so for  anyone struggling to get it to work  poking or stabbing the screen with a special screen pen works...just dont ask how!
2018-3-24
Forestjim
Flight distance : 6606519 ft
You are a lifesaver. I’m a Apple boy and I’ve always Slid not ‘poked’
I’ve been hot swapping my Iphone to Crystalsky to make functions like Histogram work.
So Apple slide and Andriod you poke. Lol
Thanks
Marty
2018-4-17
FlyLight
Now that everyone has that sorted out (YAY!!!) can anyone advise how to make Histogram ON the default setting?
I seem to have to switch it on every time. As a photographer, I use it ALL the time and would love for it to just be on, since I can easily switch it off with the x in the corner if I don't need it.
Using Moto G4 with latest version of app.
2018-4-24
Michael_Rapp
Flight distance : 204173 ft
I've been having this issue too, (Spark), and it's been bothering me ever since. One it worked, then the histogram was gone. All the sliders mentioned abvoe have reset themselves. (sony Xperia XA2).
Just fired up my Spark (indoors, at my desk; kids, don't try this at your home, at least not with the props on). and it worked like a breeze.
Have to try it tomorrow on the outside.
2018-5-12
m1shootr
Flight distance : 118894 ft
Thanks for finding a solution. I also use the histogram religiously and had the same problem.
2018-5-13
Johny5610
South Africa
Hi All, greetings from a rather grey rainy Johannesburg, South Africa. I have just joined the forum and this is my first post. I had a problem running the Go 4 app on my Samsung Galaxy S5, in that the Histogram would not load. When I went into the camera settings and changed the slider to "On", as soon as I closed the settings menu, the slider moved back to the original position. The same applied to the "AFC" slider, which is turned on by default and the "Overexposure Warning" slider, which is turned off by default.  Having searched for a solution on the various forums, I found quite a few threads in both the Mavic and Phantom forums but was unable to find any solution...…. and so I persisted in the app experimenting to see if I could find a way to get them to hold their position..... then suddenly the Histogram popped up. I realised that if I tapped on the slider instead of sliding it, the button would move to and hold its new position. It worked on all three sliders. Just thought I would share this in case there are still others out there battling with the same problem.
2018-5-31
MTrouty
I finnally got it to work. Ive spent a month on this. Not sure what I did to make it work but its to do with the setting. Things I did change was change anti flicker from 60 hz to 50 hz. Other changes were ntsc moved to pal. My AF Focus assitant still doesnt work or overexposure warning. But MF FOcus assistant works now along with histogram
2018-7-25
MTrouty
2018-7-25
MTrouty
2018-7-25
Elester
Good day i have just received the phantom 4 pro + and i also cannot get this to work on the bilt in system? No historgram, over exposure warning auto focuse assist ect. what gives any info on this from DJI I also get rest camera faild when i try to reset camera settings. I will check all my other devices. Phantom 3pro and Crystalsky.
2018-7-28
Elester
2018-7-28
solentlife
Flight distance : 1087530 ft
Latvia
I know OP is talking P4 ... but the P4 people are not alone with this .... myself and others I know have similar with P3's ...
Its selected in the options and most times will show when starting up ... but after a minute or so of flight vanishes ... or it just does not show when starting up. Checking menu items shows it selected ..
Annoying to say the least.
While not showing if I go to menu unselect and then reselect it - up it comes and it stays for rest of flight.
Nigel
2018-7-28
Forestjim
Elester Posted at 2018-7-28 05:28
Easy fix. Poke it on.... don't slide.
I did the same thing when I got my Cystalsky after coming of apple.
There seems to be a little bug and CS and Android in-camera functions.
Don't slide on option or it will turn green but when you go back it won't be engaged.
Don't slide - Poke it on...  for the Histogram and overexposure warning.
2018-7-30
dyVinter
Johny5610 Posted at 5-31 07:11
Hi Johny5610,
Thanks for your tip, it actually works with "tap on it, instead of push" have also tried long, until I have read your tip
2018-11-24
Nigelpugh7
Flight distance : 3507470 ft
Forestjim Posted at 2018-7-30 01:42
Thanks for the tip.
Yes your right, pushing the button instead of sliding work!
Brilliant thanks so much!,
2019-3-31
Paul Patterson
I found this forum thread because I too am unable to get the histogram to show on my Motorolla Moto X4. Mine behaves loke Drogo2 user. I do have a Nexus tablet. I will try it on that device knowiing that the Moto X4 is not a powerful smartphone.
2019-7-20
mowhoe
I have this same problem, not sure how to fix it???
2021-1-5
12
