Montfrooij
Flight distance : 2399075 ft
jake daniel Posted at 2018-1-26 05:40
hmm you right, which means if software interchange it will not behave as expected, which means dji must design a new controller. I don't understand why they have not see the advantage of having the gimbal dial on the right hand side as we are in major using right hand. for sure we will definitively get better results. Is there anyone who is equipped with the proper tools to try swapping these two commands?
The way the left dial works is best suited for gimbal changes.
You can make graduate changes and vary the speed of the motion by turning further.
And it has a 0 point (no movement).
The right dial has no 0, so that seems not suitable for controlling the gimbal. As that needs a 0 point to be able to remain at the same position.
So, how I see it, you will have to change the hardware.
