marcel_911
Flight distance : 18901 ft
From the stats.Mavic Air: 4000m (FCC) 2000m (CE)
You can infer from this that we in Europe are not allowed to transmit at the same power as in the US so we have reduced range.
But of a bummer but what can you do?
... until you look at these specs ...
Mavic Pro 7000m (FCC) 4000m (CE)
Hmm. So it can't be a limit on transmitter power in the EU causing the reduced range.
So, if the rame is 4000m in the US then 4000m must be possible, so why is it limited in the EU/UK? They both use the exact same band on 2.4Ghz.
