Phil-from-france
Flight distance : 57556 ft
Following my battery falling out during flight, dji support have sent me a label to send the drone back as I had a Gimbal overload warning.
I just wanted to just double check it before boxing and sending it back, and it seems that it’s working fine now.
Should I send it in anyway? I’ve lost a battery in the process, but I don’t know whether they will address that issue..,
It seems that you can fit the battery and have it connected, but you have to give it a good pull to make sure it is properly locked on, otherwise it can take off and fall off, even though it seems to be locked in. This should be made very clear by DJI to avoid this happening to others, as a battery falling off in flight and landing on someone is a very real possibility!
