Hi,
When I fly with my mavic pro at higher speed (about 30 km/h), picture in video is pretty choppy, especially around edges. Settings was: 4K, 4096 x 2160, 24 fps, shutterspeed about 50.
When I try lower resolutions, same thing happens.
I'm new owner and I don't know what is the problem?!
Can somebody help me, please.
Hi there, please try to decrease the resolution and choose higher frame rates and see if it is the same situation, I suggest test different resolutions with different framerates. Thanks.
DJI Thor Posted at 2018-1-29 00:36
Hi there, please try to decrease the resolution and choose higher frame rates and see if it is the same situation, I suggest test different resolutions with different framerates. See if it works.
BTW, if the computer configuration doesn't meet the need for playing C4K videos, it might also look choppy. You can try to change another player or PC. See if it helps.
DJI Thor Posted at 2018-1-29 00:45
I tried to record in a lower resolution and same thing happend, so I do not think it's a PC problem.
Are you sure you are capturing with a shutter of 50?
That looks like its shot at a higher shutter speed to me, no sign of motion blur, each frame is sharp.
Are you transcoding your footage before editing. Is your workflow 24fps from ingestion to output?
Could you dropbox link an original, unedited clip straight from the card? So we can have a bit more of a look at whats going on with the footage.
Malakai_UK Posted at 2018-1-29 01:57
Yes, shutter was about double of frame rate because I took care about it.
I can sand original file from sd card but it's 1,74 gb!?
How can I trim it without formating?
Here is the link of original video: https://drive.google.com/open?id ... XKNmdOVPfs-8zKdOsWB
This was a test flight so do not pay attention to the composition.
Keep attention to the first part of the video because later I changed settings and resolutions.
