bob37
Flight distance : 260384 ft
I did a test where i intentionally flew over and then beyond very large power lines to see what interference i might get and my P3A flew perfectly to about a mile with the signal going directly through the array of high-tension cables; when i lost contact and RTH was initiated. So, power lines offer little interference. There is one very large home that i tried to fly over, and every time i tried, I lost contact and my bird came home. I tried several times, once from only a short distance away, and it happened again. Something in that huge home blocks my signal.
I would guess, if this happens often to you, it is internal to your P3 either soft or hardware. I am sure others here will offer more in-depth advice. |
