Phantom 4 motor vibration update
12Next >
11088 59 2018-1-29
fans1f690efe
I was having serious motor vibration after latest firmware update. What I did was, I went into basic gain setting and changed the yaw setting from 100% to 80% this has taken most of the vibration out and now only a slight shake remains after releasing the left stick. So if anybody else has this problem I'd suggest playing around with gain settings
2018-1-29
Juliano Cruz
Flight distance : 4158868 ft
Brazil
Mine has this issue sometimes! DJI, any position about this problem? I am afraid shell cracking issues due that vibration.
2018-1-30
RedHotPoker
Flight distance : 165105 ft
I'm happy to hear that you were able to do a self repair.
Those are the best. & no down time..
RedHotPoker
2018-1-30
Kokok
Flight distance : 1802159 ft
Philippines
Ive noticed this on mine also after the latest update.
I spooled up my p4 on the workbench with the propellers detached. Thats when i heard vibrations during spool up. No observable vibrations from the motor shafts and motor housing/bell though.
Any thoughts on this?
Thanks
2018-1-30
fansa84fe8a4
Flight distance : 3 ft
Kokok Posted at 2018-1-30 23:28
Did you also do the VPS calibration after the update?
I installed .700 via GO 4 and did the VPS in Assistant 2 (Which would not allow for the firmware update in Windows so I had to use GO 4 through the iPad.).  I believe the VPS affects the drone's flight near the ground.  It was so smooth I could have done a waypoint mission at 3-4 inches off the asphalt.  Landings were light as a feather.
2018-1-31
fans1f690efe
fansa84fe8a4 Posted at 2018-1-31 08:54
No it was vibrating  with the props detached ,sitting on a bench ,when the motors where slowing down.
2018-1-31
owiecPL
Flight distance : 112805 ft
Singapore
Mine P4 has the same vibration after start motors. Any value of gain (80-120%) doesnt solve shaking motors.
I'm afraid it could destroy motors... DJI ???
2018-1-31
fans1f690efe
What I did was, went into basic gain settings changed the yaw setting from 100% to 80% , this has taken the majority of the vibration out. DJI need to look at this again or we all going to have cracked shells
2018-1-31
Pareja IV
Flight distance : 1084961 ft
Same issue here, I haven't done a flight test yet, but very important vibration without props when releasing the throttle stick after powering it up, just before the motors get a quiet revolution state. Yaw gain at 80% improves the vibration but it is still present
2018-1-31
fans1f690efe
Pareja IV Posted at 2018-1-31 13:34
Yes your having the same issue as me. So DJI had 7 months to give us a stable firmware., but guess what, it not all stable. Well done DJI , NOT
2018-1-31
Pvt Pilot '79
Flight distance : 1000272 ft
Are you guys sure you should be spinning those motors up without props? I’m not sure how DJI governs the RPM’s but I certainly can see over speed causing vibration and possible failure.
2018-1-31
fans1f690efe
It's the same issue  with the props on.it happens when the motors are slowing down
2018-1-31
fans1f690efe
2018-1-31
Juliano Cruz
Brazil
DJI, any position about it?
2018-2-1
bugbee
Flight distance : 167556 ft
The motor arm shook like 60's harley Davidson motor cycle when I landed the drone after update.
2018-2-1
Juliano Cruz
Brazil
bugbee Posted at 2018-2-1 15:12
Yes, I realized the vibration without the propellers and during the land. Take off is all ok.
2018-2-1
fans1f690efe
Surely somebody at DJI test firmware before releasing.  This new vibration issue could potentially be a dangerous issue. If the new firmware hasn't been tested prior to release, it's totally irresponsible and dangerous on DJI's  part
2018-2-2
Archangel3356
Flight distance : 4655896 ft
Yes. I can confirm this vibration upon landing also. Phantom has been flying well since firmware update but I did look for this today for the first time and tried several closeup landings. This does not look healthy for something that flys. I would not be flying my Cherokee with a vibration like that. Somethings up. What ?
2018-2-2
fans1f690efe
Archangel3356 Posted at 2018-2-2 14:46
DJI Susan suggested not to fly with this issue, but unfortunately Iam unable to send flight logs ,as my PC is down , hopefully somebody else can forward the data to DJI.
2018-2-2
Kokok
Philippines
Yes i did all the calibrations.
I investigated this issue further and found out that the vibration occurs everytime i power up coming from idle motor speed, and powering down to idle motor speeds. These were done when the p4 was on the bench without props.
During test flights, i cannot observe any significant effects this has on the flight performance. But as with any flying machine, vibrations are bad and it will cause damage to the p4 airframe/shell.
Has dji confirmed this issue?
2018-2-2
fans1f690efe
Kokok Posted at 2018-2-2 20:53
No conformation from DJI on this issue,  silence from DJI, typical really.
2018-2-3
Archangel3356
I’ll be happy to post my data files if requested of me. In the mean time I think I’ll look and see if beta 6 is still available for me to fall back on.
2018-2-3
Nabe
Flight distance : 1627031 ft
Japan
I am in the same state.
It was aircraft firmware occurred from ver.02.00.0106.
2018-2-3
Archangel3356
As kokok stated above, the vibration is through all four arms when you first spin up the motors past the idle speed and happens again when they spin back to idle speed. Props on or off, it’s the same.  But it flys perfect and I went out over 6000 feet yesterday and all systems worked flawlessly. Not sure how much of a concern this is, maybe no concern at all and it looks worse than it is but I’ll be sure to keep my eye out for any fix. Not holding my breath for any new firmware for the P4 since its been discontinued makes me believe they might not be interested in supporting this bird any longer. Only time will tell I guess.
2018-2-4
fansa84fe8a4
I didn't notice any odd startup as I pop it up into the air pretty quick, but when I brought it in for landing and once it was firmly on the ground and I held the lever down to shut it off, there was a howl and shudder.  I thought a bearing went out just then, but maybe it's just the way it behaves on shutting down.  Props spun by hand freely and no noise or grinding so bearing is ruled out.
I haven't tried it with auto-landing to see if it is any different.  Other than that, it flew fine.
2018-2-4
fans1f690efe
fansa84fe8a4 Posted at 2018-2-4 08:02
It shouldn't behave like that on landing,. There's definitely something going on with the motors
2018-2-4
DJI Susan
Hi there, sorry for the late response first as I just received the message in PM. Regarding the wobble, does it only appear on the ground? We've received some feedback on the ground, but not appear in the air. Our engineers have been aware of this and will fix it soon. If you meet wobble in the air, please export the flight logs for further analysis, thanks!
2018-2-8
fans1f690efe
Hi Susan, it's hard to tell if it's happening in the air, but it's definitely happening on the ground. Hope this helps, I turned down the  yaw from 100% to 80% in the basic gain setting and this took the majority of the wobble out , however there is still some vibration there
2018-2-8
Juliano Cruz
Brazil
DJI Susan Posted at 2018-2-8 02:31
https://www.youtube.com/watch?v=SMb1RD5pPOg
I realized it happens only on the ground when I change from idle to throttled and from throttled to idle. I will keep watching if during the flight it occurs... if so, I’ll send you the log files.
2018-2-8
Giorgos007
Flight distance : 217218 ft
Greece
The vibration is happening on the ground when you throttled the motors to take of and again when the motors go back to idle speed.in the air i havent see any vibrations it flys perfect without problems.now we waiting dji to solve the problem
2018-2-9
dronybaloney
Flight distance : 24897940 ft
Wel i brought the p4p yesterday back to the shop , discovered stress cracks at partition of 2 air vents on the arm. I have posted a post before regarding the notice of vibration in arms upon take of and landing when drone is in contact with ground. I regular inspect the drone for cracks and unfortunately discovered 2 small hairline cracks.it all started after update p4p to .700 fw , not with .602. Its still under warranty, so i hope dji repairs it under this warranty and not finding another excuse. I have reported this many times before. Its very strange that these hairline cracks are in the left front arm and the right back arm airvents
2018-2-9
F.KOK
Flight distance : 18954370 ft
Namibia
Hello Susan, please inform the engineers that the motors do not vibrate when the Drone is turned slightly forwards or backwards, ? but when it is level or when you push on the Drone it vibrates.
I still have the wobble when flying fast in P,S or ATTI mode. When flying slow the Drone flies perfect. When flying with the wind it flies perfect, but flying into only a slight breeze it starts to wobble as mentioned before. Everything is on the latest version.
2018-2-10
Farmflyer321
Flight distance : 236250 ft
I have the same issue after last update. Seems to be ok in the air. But on the ground scary.  If this causes a crack or other problem i will be  very upset with DJI.
Its a major problem and need to  be fixed.
2018-2-12
Farmflyer321
Farmflyer321 Posted at 2018-2-12 01:59
It seems to be the right rear arm on mine
2018-2-12
Farmflyer321
Farmflyer321 Posted at 2018-2-12 02:07
Have just been investigating further. My screws are tight i would be scared to try and make them tighter. At idle there is vibration with or without props. Definitely worse with props on. And as i take off it get real bad but then in the air not reallly noticeable. Flight seems to be ok maybe not quite as stable as it was before. I have never crashed or had a hard landing, everything still seems ok no cracks but i am worried of this causing a crack or crash.
2018-2-12
dronybaloney
Hello susan,
anymore information regarding wobbling upon startup and landing from the engineers?
I will receive my p4p back soon from dji repair , as I discovered cracks in the engine arms (btw they repaired it under warranty luckily) but I don't know now what to do , keep flying or downgrade firmware back from .700 to 602 ? please advise as soon as possible
thanks
2018-2-17
fansa84fe8a4
fans1f690efe Posted at 2018-2-8 02:47
Interesting about the lowering of the gain control of Yaw <100%.
In the Inspire 2 side, they recommended lowering the Pitch to around 87% and leaving the others, including Yaw, at 100%.
This is confusing.  Okay maddening too!
2018-2-18
DJI Susan
Thanks for reaching us. Have you tested the performance in the air? Generally, the recording will be affected if the drone wobble in the air. Please keep us posted on the test results, thanks!
2018-2-23
DJI Susan
Juliano Cruz Posted at 2018-2-8 06:10
Noted with thanks! We'll wait for your update.
2018-2-23
DJI Susan
dronybaloney Posted at 2018-2-9 23:49
I have replied your post of P4P: https://forum.dji.com/thread-136078-1-1.html please keep us updated there, thanks!
2018-2-23
12Next >
