15matjan
Flight distance : 1158258 ft
fansb1fe1104 Posted at 2018-2-8 20:27
The nearest airport near where I live is 4.7 miles away according to the B4UFLY app. This airport is a small grass field with no control tower. I used to get class D warnings when I fly at home, but I have not seen that warning in a while. The nearest bigger airports near me, one is about 8 miles away and the other is about 10 miles. Mostly the small planes seem to fly over 500 feet. Occasionally it appears to me that the smaller planes are below 500 feet, possibly 300-400 feet. Again its hard to know for sure because its impossible to tell how high they are from the ground. Helicopters seem to like to fly pretty low too. So being more than 5 miles from a bigger airport with big planes, usually Lear jets, although the other day I saw what I would guess might be a 737. The other day when I took my dog to the park near me to walk around, this park is just outside the 5 mile mark for the grass field, and about 8 and 11 miles for the larger airports, this large plane (possibly the 737) looked to me like he was flying maybe 200 feet over the top of the trees. He flew almost directly over me and I could clearly see all the markings on the jet. That's what aggravates me and worries me these planes that seem to be flying so low. Unless its an emergency I can't see any reason why jets would be flying so low so far from where they are landing. This one jet I have seen very low quite a few times so I know its not an emergency. If I had been flying my phantom at the park that day and was at 300-400 feet if I tried to see and avoid when it came through I could very well have crashed into it. If that happened I would be the one at fault because all drones must yield the right of way to manned aircraft no matter what the altitude is the drone it is the one who has to see and avoid. I don't fly at home much anymore because of this and if I do I don't fly any higher than the trees. Ok my rant is over now, sorry that was so long.
Difficult case. You may be right and have the law on your side, but, given the actual trends, if anything happens they'll tend to believe more the plane's pilot.
I'd check the AIP in that area and if there are any flight restrictions (level, path, etc) in the area of those trees, I'd notice it to flight control authority.
A, too brave pilot, is dangerous to air safety, not when approaching that airfield but, presumably, other airports and airfields too |
