Genghis9
BucklesTroy Posted at 2018-1-30 18:18
Thank you for the responses. We would be flying near stand alone buildings in some instances and downtown areas in other instances. So this would vary. It looks like I have some research to do, so thank you for pointing me in the right direction.
We have been considering an Inspire or Matrice 100 for these type of inspections. I haven't been able to find the wind resistance specs for them. At half of the Inspire top speed, that would put it at just under 30 mph. Would there be a large enough benefit to using an Inspire or Matrice over a P4P? The P4P camera resolution is plenty for inspecting sealant joints around windows and such, so we're more concerned about the performance of the aircraft.
You are kinda mixing apples and oranges here a little bit or maybe I should say you are setting up a quandary
The faster the wind speeds go the more turbulence and sheer you'll get, and of course, the higher the speeds may get still if being funneled through other buildings.
All this means is that getting some thing that flies faster funnier does not necessarily give you more ability to fly in stronger winds as a direct translation. At best, you can use a stronger drone to ensure you can operate but in lesser conditions than it was designed for because you'll need that pad to cover the increased speeds and turbulence that you could find the higher up you go and the turbulence you could encounter.
Meaning, a P4P could be used in near ideal conditions with calm to light winds. While a Inspire/Matrice can operate in conditions that are at the limit of the P4P but again at altitude the conditions could be at the limit of the Inspire/Matrice. In other words you need a pad of capability to cover the range of conditions you may experience.
Regardless, no matter the size and capability you have, as already mentioned, updrafts, downdrafts, and turbulence will challenge any aircraft especially lightweight ones. |
