I am a relatively new pilot. I am trying to start using waypoint mode.
When in waypoint mode what all control do you have over the drone? Can I control the camera (up and down)?
Can I control what direction the camera / drone is facing?
Can I control the altitude whenever I want?
Can I adjust speed whenever I want?
Hey Evan, after tapping “Done” and a new menu will appear showing you to set the heading, speed, and action to perform when the mission has completed. You can choose the direction your aircraft should point as it travels to each waypoint, choose what the aircraft should do when the mission is complete, and set the speed at which your aircraft should fly. I'll attach the tutorial video for your reference.
