Stratcat
Flight distance : 4283012 ft
Andrew245 Posted at 2018-2-8 12:02
mismatch of what software, the go 4 app ? please note , I have been able to idle the engine before at first setup after calibrating the craft, I had the green bar ready to fly on at the setup and at the testing stage idling without props on it all worked perfectly, I even take the craft later that week for a test flight it all worked great, then week later the app on the same firmware the same go4 version prompts me for a mandatory upgrade and grounding P4P... does that make sense ? Btw the updates had been disabled on my android device so the app would not update unless DJI has a back door to simply tell you what to do with your investment... If this was a glitch I can take it, no problem, but if they can simply enter your device any time they feel like doing so then this is a privacy invasion and that is what makes me really mad...
It's like you bought a tv from Bestbuy and while you're at work bestbuy tech enters your house without your knowledge or permission to update your tv lol , how would that stand with you...
The P4P is a RTF straight out of the box... you should not be told or enforced what to do with the product you just bought.. Just saying...
You should be able to fly without your phone or the app. You're limited mind you, but it's not required.
The only thing I can see is the app grounding you for incompatible FW versions between the AC and RC. |
