DJI Elektra
Hi, there. Here are some tips for storage battery:
1. Do not leave the battery near heat sources such as a furnace or heater. Do not leave the batteries inside of the vehicle on hot days. The ideal storage temperature is 22℃-28℃.
2. Keep the battery dry. Never drop the battery into water.
3. Do not drop, strike, impale, or manually short-circuit the battery.
4. Discharge the battery to 30%-50% of the battery level if it will not be used for 7 days or more. This can greatly extend the battery life.Battery discharges automatically to below 65% when it is idle for more than 10 days to prevent the battery from swelling. It takes around 2 days to discharge the battery to 65%, It is normal that you may feel moderate heat emits from the battery during the discharge process. Set the discharging thresholds in the DJI Go app.
Thanks for your support.
