Nigel_
Flight distance : 388642 ft
Joerg62 Posted at 2018-2-5 15:28
Thank you for taking a look. That is what it looks like to me. Like someone just pulled the battery in mid air. But I always make sure it is securely attached, and I found it right next to the drone.
By flight controller, do you mean the remote that I use to control it? I'm curious, what makes you think the remote failed? Or are you referring to some component in the drone?
By flight controller, I meant the thing in the aircraft that monitors the sensors, tells the motors how to keep the aircraft stable and on course, and writes the log file.
If the battery had come out, I suspect the aircraft log would contain that information if DJI look at it in enough detail, I probably haven't looked in enough detail, they can see a lot more detail than I can, but a battery falling out after several minutes in the air might be considered a warrantee issue too.
If it is under warrantee then the easiest is to let DJI analyse the log and report their findings, they will either tell you what you did wrong and offer to repair it, or replace the aircraft. Sometimes they can't tell what happened but that is almost always when the aircraft has disappeared and there is only the phone log to look at.
If you submitted your request late Thursday then they have only had Friday and Monday to look at it, if they are busy then it may take longer, do make use of the chat to check on progress though. |
