fans8ea2660d
Flight distance : 122822 ft
fans8ea2660d Posted at 2018-2-5 12:28
Having the same issue with my Mavic Air (got it last Friday and have had a total of 8 flights now). Prior to the first flight, I calibrated the IMU and compass. The several flights were indoors, no issues. I tied it outside yesterday (was below zero outside), and thought the unit was going to explode as it was shaking so badly. I managed to land it and go back inside. I tried it again indoors, and it happened again, but only for a few seconds. What was also odd, is the unit started to yaw without a control input. Landed it and tried it again, seemed OK next flight. Not sure if the issues are specific to my unit or if others are having similar issues.
Some good news, I dialed back the gain as suggested by others, hovered inside for a minute to test the setting, then went outside with the unit without restarting it (still had 90% battery). I did not experience any shaking while testing with an outdoor temperature of -16C. I'm not 100% sure if the issue was eliminated by adjusting the gain, or if the unit had warmed up sufficiently to eliminate the issue. I'll run with it being sufficiently warmed up. |
