RappeFiets
Flight distance : 139642 ft
Matthew Dobrski Posted at 8-2 15:41
Not normal, but typical. Mine P4P+ has this shake at the beginning of lift off and at the end of landing, Once airborne she's pretty stable. Are you using Auto Lift-off feature or launching manually? Try both to see the difference (if any at all), also try to disable bottom sensors. Be persistent performing lift off, just shot her up 5-6 m to hovering position and perform routine maneuverings there as usual. I just calibrated the sh*t out of my phantom and did a firmware downgrade, then upgraded again and restored to factory settings. It seems to be better now. It wobbles still sometimes but not on a regular basis and a lot less. In flight it does not seem to have any problem. |
