lannes
Flight distance : 4465 ft
TheMann58 Posted at 2018-2-18 19:00
Iannes,
Can you confirm if I update my CS UB to firmware ver. V02.50.00.00 I will lose access to all downloaded maps on the CS? Are the downloaded maps deleted from the CS, or are they still intact, but the CS just cannot access/use the Here map files any longer after the update?
It's a bit of a catch 22 your in.
If it was me , I think I'd like to protect against a back light failure on the CS U, so I'd upgrade to latest firmware and DJi Go 4 4.2.4
I'm not able to verify if the maps will gone on the update, I suspect they will be as Mapbox is used instead of the previous here maps
If your not having overheating issues , I guess you can stick on the old firmware.
Just out of interest when was your CS UB built, http://tools.retroroms.info/
Put the serial number which is under the QR label into the serial decoder |
