Matthew Dobrski
Flight distance : 1831050 ft
Geebax Posted at 2018-2-9 18:20
'How secure is the Phantom 4 Pro against this sort of attack, or indeed, any other type of attack/hack? '
The first thing is to understand that the P4 aircraft does not use WiFi at all. It has a radio connection of a proprietary nature (Not WiFi) connecting the airccraft to the RC unit. The RC Unit has no WiFi either. The only possible WiFi connection is the phone or tablet you use to control the operation, so if you disable WiFi on that device, there is no mechanism to hack into it.
OK, it makes sense. Now, let's assume the following scenario:
1. DJI drone is up to date, flying just charmingly on my property, no issue whatsoever, no NFZ in 500 miles radius.
2. Traveling 1000 miles away into total wilderness, no NFZ in 500 miles radius (checked at home), no WiFi, no cellular, no humanoid even within VLOS ... and no flying also ... Aircraft Disconnected, no video feed, RTH auto-activated.
3. No luck with re-boot after landing, drone's blind.
4. Back-up drone is blind as well, disconnected.
It's happen to me at least three times last summer in random places. Drove to nearest village and drone was back in order. Go figure.
The question is simple: how to avoid such situation this coming season? Would WiFi disabling eliminate any ways of ingerence into my freedom to fly, beside obvious NFZ restrictions?
