Gerry1124
With everything powered up, the little light will be green right above the camera lens. When you push the small button, the light will turn red, that button is the onboard video on/off button. When it is recording, it is RED. I got the same message about turning off the camera also, I just clicked ok and did the upgrade, then power cycled and went to the info screen on the app. It told me there was an upgrade for the battery, so I clicked on that and ran the upgrade and power cycled again. I had to install all 4 batteries to upgrade the 4 of them. After, I installed each battery, and started the p2+ and moved the sticks to full climb and side to side. works great for each battery. There is also an upgrade for the app on your computer so don't forget to upgrade that also. In the upgrade for the app, you can now change the altitude in the GO HOME MODE from default 63 feet to anything you want. |
