What Android device did you use to fly your P3? [Confirmed Devices LIST]
1234Next >
16196 139 2015-4-30
bomberuk
Flight distance : 16759 ft
Samsung galaxy tab 4 10.1 works perfect
2015-5-15
miles.furnell
Just got my P3 today. I side loaded DJI Pilot to use on a Kindle Fire hd 7 (4th generation) but am getting no video signal. It flies and records just fine but I can't see it. The app version is 1.0.10 and the new version isn't available from the 1mobile app I used for side loading. Any ideas on how and where you can side load version 1.1.0? I'm hoping that the problem is simply an incompatibility issue and not something more serious, but already owning an older i-pad, an iphone 5 and a Kindle Fire (all of which are incompatible) I'm not keen on having to have to buy yet another device.
2015-5-15
eThug
Works perfectly with my One Plus One. I have a P3A.
2015-5-15
skycam
Nexus 7 2nd gen works fantastic.
2015-5-16
sveilien
ksdigitaldavid@ Posted at 2015-5-3 06:08
Anyone gotten their Galaxy note 4 to work? I tried and it didn't see the p3 when registering. I have ...
Works great on my Note 4 with a custom Lollipop rom with pilot app 1.1.0
2015-5-16
BAnder7192
nurimanizam Posted at 2015-5-2 21:58
Confirmed working on my LG G3 if anyone's wondering.
How did you get your G3 to work?  I've updated and I don't get the registration.  The gimbal responds but no video or information through the app.
2015-5-17
pbedford
Thailand
I have got it working on an old Galaxy Tab 2 7.0 1GB RAM running kitkat, it's not perfect but it works.
2015-5-17
Gary
Note 4 working fine. Android 5.0 Pilot 1.1.0
2015-5-17
Gary
I'm flying a P3P with both a Galaxy Note 4 (Android 5.0) and a Galaxy Tab 8.4 (not handy to check OS version). I did notice that on the Note 4 yesterday that when using  the camera in manual settings mode that the small camera EV/Speed/ISO settings window seemed to be covering my map swapping window and  I may have had to revert to camera auto to get to the maps. I'll try this again soon but I plan to map the Custom button on the right bottom to switch between map and camera views anyway so this could be a non-issue if it was the case.
2015-5-17
blauer
Flight distance : 209403 ft
Was using iPhone 5s but wanted bigger screen and don't want ipad.   Went to verizon store today got Ellipses 8 for $30 (+$10 per month)  works great. Made sure to test it in store,  brought my p3a with me and did a demo for the guys at the store.
2015-5-22
niktnowy
I have Samsung Galaxy 8.4,   It works just perfect
2015-5-22
lon.garwood
South Korea
I use the Samsung galaxy note 4 edge.. works fine.
2015-5-22
giant
Flight distance : 31565 ft
I bought a cheap LG Gpad 7. The white one. It is as if it was made for the Phantom 3. Very responsive, good image quality, runs like a charm.
2015-5-23
yvesvn
Flight distance : 840879 ft
Belgium
I am using Nexus 10 (works fine) I hope HDMI output works also with my DVR (ordered new cable HDMI to AVR)
My Nexus 5 as mentioned before works also but screen is smaller than the Nexus 10(hi)
2015-5-23
MikeAngelo
Galaxy Tab3 and Droid Turbo both work well.  The Droid Turbo is more stable......but, smaller screen
2015-5-23
nurimanizam
Singapore
BAnder7192 Posted at 2015-5-18 10:37
How did you get your G3 to work?  I've updated and I don't get the registration.  The gimbal respo ...
Make sure Phone is in PTP Mode and not MTP Mode
2015-5-23
zlatolist
Flight distance : 69610 ft
Slovenia
Samsung Galaxy tab S 10.5, SM-T800, 16Gb, ver.: 4.4.2, works perfect, same on ver. 5.0.2
2015-5-23
rawmediastudios
Works with my Nexus 10 running Lollipop.  HDMI output works as well.
2015-5-23
sblake
Flight distance : 39308 ft
zlatolist@gmail Posted at 2015-5-24 00:51
Samsung Galaxy tab S 10.5, SM-T800, 16Gb, ver.: 4.4.2, works perfect.
Were you able to get the Samsung Tab S 10" to fit in the stock holder? I bought the 10" and it didn't fit mine so had to return and get the Tab S 8.4", fits perfect and works great.
2015-5-23
zt6kxt41
giant Posted at 2015-5-23 19:35
I bought a cheap LG Gpad 7. The white one. It is as if it was made for the Phantom 3. Very responsiv ...
Thank now I need to try mine again
It did not work about 2 to 3 weeks ago.
Is yours with WIFI or WIFI/4LTE
2015-5-23
apocnz
Flight distance : 106588 ft
Acer Iconia Tab 8, running Kit Kat, works fine. P3A
2015-5-24
ianbradbury34
Flight distance : 218435 ft
Malta
Using a Samsung Galaxy Note 8 and it works fine.
Only issue is screen brightness...I can''t see it in the sunlight.  I can on my iphone 6 luckily.
2015-5-24
giant
zt6kxt41@gmail. Posted at 2015-5-24 10:54
My G Pad is a LG G Pad 7.0 V400 Wi-Fi 8GB . I put nothing else on it except the DJI app. I have to clear the disk space regularly by removing the cached videos because there is only about 4 GB left to use of the advertised 8GB. Some apps can be installed on the micro SD card. Unfortunatly the DJI app and its contents are all written on the main disk. But as I said, it works perfectly.
2015-5-25
zt6kxt41
giant Posted at 2015-5-25 19:51
My G Pad is a LG G Pad 7.0 V400 Wi-Fi 8GB . I put nothing else on it except the DJI app. I have to  ...
Thank Giant....I will keep trying but right now its a no go for me
2015-5-25
giant
zt6kxt41@gmail. Posted at 2015-5-26 01:13
O by the way, I did the upgrade to Android Lollipop before I tried...
2015-5-25
zt6kxt41
giant Posted at 2015-5-26 04:39
How do i get that....I am on AT&T for data and it is saying my Software is current
Thats probably the missing link
2015-5-25
zlatolist
Slovenia
sblake@rocheste Posted at 2015-5-24 09:46
Were you able to get the Samsung Tab S 10" to fit in the stock holder? I bought the 10" and it did ...
I have a photo stand and sun protection, more comfortable, height is adjusted ...
2015-5-26
BAnder7192
nurimanizam Posted at 2015-5-24 00:14
Thanks.  I got it to work.  I wasn't paying attention to when I plugged in the usb to what was on the screen.  Thank You!
2015-5-27
antlvk
Flight distance : 539347 ft
Malaysia
Lenovo Tab 2 A7-30 (A3300) and Samsung Note 3 SM-N9005
2015-5-27
bluemagic
Flight distance : 1129629 ft
Note 4 works. But now getting video lag while flying. Unit gets hot. Has gotten worse wioth latest firmware it seems.
2015-5-30
fritz
Seems to be working fine with my acer irconia 8  i bought on CL for $50
2015-5-30
kalin2011
I also have an Iconia A1 which works well, however, can't see the screen for the glare!
2015-5-31
Stergios
Greece
samsung s3
samsung s4
thl w8s
works great!
2015-5-31
nathanrowe
Nvidia Shield 16gb works great.
downloaded app via DJI website and installed as an .apk file. App has not cutout on me and is nice and smooth. (freshly wiped tablet to ensure minimal background apps running) HDMI out on the shield is perfect while waiting for the upgrade hdmi out for controller. HDMI lead goes to a small ebay video convertor to RCA video out staright to fatshark goggles work perfect and get all the telemtry data on screen too. if you open the pilot app without the phantom on you can go into settings and select whether or not you want telemetry data on the hdmi out. this option dissapears once you fire up the phantom?? maybe this is for the inspire and they'll release this option once the hdmi upgrade comes out..
2015-6-10
llll
I got a Dragon Touch M8, 8" tablet running KitKat. $90 from Amazon, HDMI out, GPS, 1280x800 decent screen, fast processor -- installed & ran Pilot app flawlessly on the firs try, solid connection to aircraft.
2015-6-10
barryfairclough
Flight distance : 387940 ft
Initially tried my Nexus 7(2013) with the app downloaded from the DJI site - worked OK but found it to be rather laggy. Sought advice from other forums and spoke to a techie at my local DJI dealer and have settled on the Nvidia Shield - very smooth, no lag, great screen size, very happy.
2015-6-10
frb113
Flight distance : 109298 ft
fda483@aol.com Posted at 2015-5-1 17:02
I can NOT seem to get a Tab 4 to work. It will connect via the app but no video to the device. Hope  ...
My tab 4 shows disconnected when I try to use it. My iPad and Iphone both work OK and show current firmware installed on P3.
Update: I found the instructions to enter the developer mode so I can do the USB debug. Working fine now. I found the build number under Settings, General, About Device. Click on the build number until it tells you how many more times will turn on the developer mode. allow USB debug and you should be good to go.
2015-6-10
raafmaker
Using Sony Xperia Tablet Z2 and experience video lagg issues, crashed one time. Uses most of the time 85% CPU power. Using latest DJI firmware and Android Kitkat 4.4.4
2015-6-10
Juan.Jax
Confirming Samsung Galaxy Tab Pro 8.4 (SM-T320)
Works great. GPU enabled for 2D under developers options.
Note: both App version supported
Version 1.0.11 - Google Play Store
Version 1.1.0* - DJI Downloads
*1.1.0 adds Director features to Home screen and support for Phantom 3 in the "Support"/help option;
However, voice and audible in flight feedback are not functional in this version. (They do work in 1.0.11).
2015-6-10
phobarb
I use a LG G2 running  android 5.0.2  At first I had some problems, was stuck in beginner mode so you could not fly more than 100 feet away. Removed pilot app and reloaded it working  now. I'm headed out to test fly it now, will post after flight.
2015-6-10
1234Next >
