RAGlover
Two issues..I'll try and keep it short, but who am I kidding... I crashed my drone due in large part to a compass issue. I had to replace the bottom half of the shell and the landing gear. I used all OEM parts. During the install everything went fine except that one of the compass conectors in the landing gear leg was difficult to connect. The other one went in just fine. It was so difficult that I worried my tweezers has striped some of the silicone from the wire connectors and opted to use one of the perfectly good compass wires from the old landing gear. Same problem, I could get it in about half way but no more. Oddly enough EVERY video I have seen showing the install of these connectors shows them having difficulty getting it in, then it cuts, and magically it's connected and they move on without another word. DJI you connect the antenna wires in the legs, why not connect the compass wires in the leg as well? It's a horrible design, but I digress. I think I finally got it connected, but it was late and I was starting the worst part of a cold (luckily not the flu I think). So I went to bed and two days later when it was nice enough fly I tested it. I have two errors, compass calibration and rear vision sensors calibration.
Lets start with the rear vision calibration. I tried the calibration on the DJI 4 Go app, in field and at the office. No joy. I downloaded and installed the absolute latest and greatest DJI Assistant 2 program, and have made sure that my firmware is up to date. I connect my Phantom 4 Pro Obsidian to my computer and go to calibration. I click through the three part tutorial and it won't let me proceed and gives me an error of "Please reboot the aircraft." I have, several times. No joy. When I click on the ? icon in the upper right, I get a blank window. WHISKEY TANGO FOXTROT?! 1) how do I get it to connect to the Assistant program? One possible solution is that the "LibUSB-Win32 - Kernal Driver" was not a digitally signed driver so Windows blocked it. I can't get it to unblock it. 2) Is there anything else I can do to calibrate my rear vision sensors?
Problem 2, the compass UGH! So I did a field calibration of the compass in the middle of an olympic-size soccor field so no metal to be found other than my thick skull apparently. It worked... kinda. It allowed me to fly but as soon as I brought it home and traded batteries, needed a new calibration. Calibrated again, wouldn't keep. I could fly using DJI app and Drone Deploy without any obvious problems. I get it back to the office and look at the compass connector in the leg and one of the four wires is busted and of the three remaining the connectors are all bent up. Since the drone had no crashed or other hits since I got the new legs, I'm guessing the connector housing was busted prior to my getting it and I didn't actually get it connected but during my trying it got busted (that would be the second one and I'm not being forcefull mind you. But what do I do about it? Order ANOTHER new set of landing gear and replace them AGAIN? Talk about a pain in the rear. Anyone else having similar issues? Can I send it back as defective? I ordered through Amazon (company requirement).
Thanks everyone.
Sincerely,
"George of the Jungle" as my boss now calls me.. watch our for that tree!
