doctrrf
You probably already have this problem resolved by now but, I'll post in case someone is interested.
The same happened with my controller after the last FW update (for reference: I had a steady green led) This seemed to work for me but, maybe just a coincidence, your mileage may vary: first make sure the bird is off. Hold down the power button about 1+ minute, then give it a couple of quick taps and hold briefly as you would in a normal power off, this worked for me. If that doesn't work try letting the controller timeout, don't touch it. It should shutdown from lack of stick movement (takes 10 or 15 minutes? I can't remember) Finally, you may just have to let the battery run down until the controller shuts off; hopefully that will clear the fault. |
