DJI Thor
Flight distance : 13602 ft
Wyke Posted at 2018-2-23 00:35
Precision landing is currently only available if you use Auto Take Off, presumably because if you manually take off you're deemed proficient enough to land
Hi, actually, if the condition available, Precision Landing will also take effect when manual takeoff.
Precision Landing function is subject to the following:
1. The Home Point is recorded when taking-off and cannot be refreshed during flight.
2. The aircraft takes off vertically (10 m).
When the aircraft is beyond 20m away from the Home Point, press the RTH button on the remote controller or tap the RTH button in the app, the aircraft will return to home, match with the image information from takeoff, move horizontally, or yaw to change its nose direction to achieve precision landing.
