Kloo Gee
Flight distance : 16783757 ft
Unfortunately I don't have anything to help you out of your situation, but in case someone else runs into similar when doing updates in the future, I'll add my thoughts....
If an update hangs like that (firmware or flysafe db), I would recommend not letting it go until the battery dies. If it does get stuck, let it run as long as possible, but do not let the battery die. It is less likely to brick your device if you disconnect it and power it off normally than it is if you let the battery die. When you power it off in that situation, it gives it a chance to close off some processes before it actually shuts down. I'm not saying it won't still brick it in some situations, but I think it is less likely if you power off vs. battery dies.
On my Mavic Air, I had a firmware update get stuck like that. I kept an eye on the battery level and once it got down to the last light blinking, I powered it off. After doing this, I was able to put in a different battery and try it again (with success).
Best of luck in getting a quick resolution and getting back out and flying soon! |
