So you bought a Mavic Air only to find out there was no SD card delivered with the drone. Mavic Air is supplied with 8GB of Internal storage, but that will not take you very far. Most SD cards are too slow for 4K footage. In this Mavic Air video, I will show you the Best 4K SD Card for Mavic Air and talk about Mavic Air compatible sd cards
DJI really should tell people to get U3 cards as standard. Saying U1 works is a bit misleading as it will not be guaranteed to work for 4K and the drone will even tell you it’s too slow! The price difference between U1 and U3 cards is very small too.
Im using samsung pro plus 64gb class 10 u3 (new one not the ("+") anyway point is its the pro "plus" and is a U3 ..... this is what most people don't realize you need a u3 for 4k footage with faster data speeds.
Generally, we advise using the recommended SD cards which have been tested and verifies and could ensure the full functions. Nevertheless, thank you for posting the tips and your work, Henrik. Well done.
DJI Thor Posted at 2018-2-25 19:29
Generally, we advise using the recommended SD cards which have been tested and verifies and could ensure the full functions. Nevertheless, thank you for posting the tips and your work, Henrik. Well done.[view_image]
What is the maximum capacity supported?
The manual says the max is 64GB, but you just recommended a 128GB?!
The limit is set by hardware, so I don't understand how the limit could change unless the manual is wrong.
