Brand NEW P4P with Battery Error
1070 13 2018-2-24
benpsut86
Like the title says, I have a brand new Phantom 4 Pro, 2 brand new batteries, and after I takeoff I get a battery error.  There's nothing showing in the battery window, everything is "NA".  Any thoughts on what could be going on?  I've tried the new firmware and then downgraded to the old firmware with no luck.  Kinda upset that I can't fly my brand new machine that cost me an arm and a leg to buy!
Ben
2018-2-24
ALABAMA
Flight distance : 10442687 ft
Did it happen with both batteries?
2018-2-24
benpsut86
Yes.  Everything shows normal before and during takeoff, and then about 5 seconds in I get "NA" in the battery menu.  It shows battery percentage on top, but once I tap on the the battery to bring up the menu, I get NA across the board.
2018-2-24
benpsut86
I think I'm just going to exchange it tomorrow
2018-2-24
StanfordWebbie
Flight distance : 178018 ft
Sounds like the right thing to do.
2018-2-24
DJI Susan
Hi Ben, may I know what's the current version of the aircraft? Could you upload a short video for double check? Thanks in advance!
2018-2-24
benpsut86
Ah crap I just packed everything up.  It's the very most current firmware that is available.
2018-2-24
benpsut86
This is what I get after about 5 seconds of hovering.  Same status when I fly it around.  I'm only flying it inside to show you this because it's almost midnight here and it's raining.  ;-)
2018-2-24
Jenee 2
Flight distance : 7852129 ft
benpsut86 Posted at 2018-2-24 19:49
Did you set the time to discharge at 1 day? That should at least be several days as the default is 10 days. Before you put the battery in the drone, do you check that it is fully charged by just pressing once and see how many lights show.
2018-2-24
benpsut86
It was set at 10, but to see if this was the cause of the error I changed it to different days to see if I could get it to do something.
2018-2-24
benpsut86
And yes, I’ve checked the batteries by the one press and all is normal.  I’ve been flying the phantom series since P2, I’m a bit knowledgeable.  My gut is saying there’s something up with the hardware in the craft.
2018-2-24
Rodger8
Flight distance : 15812070 ft
I had the same thing happen tome a week ago. Battery Error, non compatible battery, no cell information. It happened at the end of a 20 minute flight. It was the original battery that came with my Obsidian. I recharged it and it has been fine ever since , which was 10 charges ago.
2018-2-24
benpsut86
I got it fixed!  By returning it!  ;-) :-p
2018-2-25
AlanHd
Flight distance : 767762 ft
benpsut86 Posted at 2018-2-25 17:10
The sensible thing to do, why chase errors on a new drone.
2018-2-26
