OTG for Spark
12
12253 56 2018-2-25
Stevieob
Flight distance : 8287 ft
davidmartingraf Posted at 2018-2-25 19:32
My thoughts are the hard wire connection is obviously stronger but hey I got to 10,000 feet without using an https://www.youtube.com/watch?v=-8VkiY2nlic&t=2sOTG cable?
Heya.  Thats a cool video.  Im new to the whole drone thing and only just bought my Spark so this might be a silly question for you!
Your video, with the grainy jumpy imaging that looks like the phone screen while in flight.... that is direct from your phone?
the lovely fluid image with nothing else on the screen... that is from the SD card?
2018-4-11
Nodge
Flight distance : 3596 ft
EMTDad Posted at 2018-4-10 23:10
I downgraded my software for my android to 4.1.15 and tried the OTG cable...  it didn't work for me.
Hi. It's more than likely that your phone auto-updated the app. Be sure to turn auto update off and try again. OTG does work with 4.1.15
2018-4-11
Northwood
Flight distance : 6097516 ft
drewhoover Posted at 2018-2-26 07:08
You don't need to go into airplane mode, but it is recommended to turn off wifi and bluetooth. If you do not, your phone may automatically connect to the remote and disable the OTG connection.
What about cellular data? Does that radio interfere also? Presumably it does because you can cache the maps in advance....
2018-4-11
davidmartingraf
Flight distance : 108805200 ft
Stevieob Posted at 2018-4-11 03:03
Yes, the DJI Go 4 App. image is from my phone and the cleaner image only was from the Spark, I simply just edited them together.
2018-4-11
drewhoover
Flight distance : 323455 ft
Northwood Posted at 2018-4-11 04:50
Cellular data isn't necessarily required to be disabled, as far as I am concerned. My belief on why people turn it off is for a safety precaution, because you don't want any distractions mid-flight, such as calls or notifications.
2018-4-11
phatav8r60
China
drewhoover Posted at 2018-2-26 12:48
I recommend the OTG cable because it improves the quality of the entire flight through the GO 4 app. But it is up to you to not use the cable. It is only at most $10...
but now I want to ask, maybe I've been doing it wrong.
But I connect my ipad via OTG to my controller.  But I leave WIFI on and when I check the WIFI it shows the controller wifi.
But if I don't use WIFI, my controller never connects to DJIGo and gives me a green light.
So, you say I SHOULD shut off WIFI and SHOULD get a green light if I am connected with OTG?  Maybe my cable isn't good.
2018-4-11
S-e-ven
Flight distance : 5922034 ft
Thailand
phatav8r60 Posted at 2018-4-11 19:45
switch off (or better delete) the sparks wifi from device.
Switch RC on, wait till led not blinking but stays constant red
OTG cable IN the device and after in the RC
Start Spark
Give it a try, mate
2018-4-11
djiuser_draga2010
Flight distance : 11217 ft
Romania
Hello guys,
I'm new in this area, I've got a new Spark, and in Romania where I'm from , the signal get lost quite often ... , and I want to downgrade to dji go4 4.1.15 so I can use the OTG cable. I already uninstall the current version.
please help me to find the right version of dji go4 4.1.15, and how to install it.
I have a Sony Xperia Z3, and Xiaomi Mi A1, both on Android.
Thanks
2018-4-12
drewhoover
Yes, you are correct (For the most part). The green light only shows that the controller is connected to the DRONE, not the phone/tablet. The green light will always appear after a while, until the drone is done starting up.
If you connect your phone/tablet to the controller via OTG, wifi is not necessary because you are already performing all of the functions that wifi would do for you. If you have both wifi and OTG connected, you are doing two of the same job.
Let me know if you have any questions!
2018-4-12
S-e-ven
Thailand
djiuser_draga2010 Posted at 2018-4-12 01:27
Hello guys,
https://www.apkmirror.com/apk/dji-technology-co-ltd/dji-go-4/
2018-4-12
Greyscale
Ukraine
When DJI stop supporting OTG cable I sold my Spark
2018-4-12
BerkoZg
Flight distance : 2628 ft
Croatia
Im still usig djigo4 v. 4.1.14. and otg works with android Sony Z3 Compact.
2018-4-13
djiuser_draga2010
Romania
S-e-ven Posted at 2018-4-12 05:21
thanks a lot ,
I just installed dji go4 4.1.15 , and I hope that I'll have time to test it in this weekend, and I'll give a sign about how it works.
all the best
2018-4-13
djiuser_draga2010
Romania
BerkoZg Posted at 2018-4-13 03:05
I'll test dji go 4 v 4.1.15 with otg, on android Sony Z3 , and I'll give a sign.
all the best
2018-4-13
S-e-ven
China
djiuser_draga2010 Posted at 2018-4-13 14:57
all the best
It worked today on my phone ;-)
(Sorry, quality is not so good. Used only phone for the little planet.)
2018-4-14
BMelody
Flight distance : 3146 ft
I have a pair of Epson Moverio glasses currently running DJI GO 4,  4.2.8. I would like to use 4.1.15 to get the OTG feature back. I am running 4.1.15 on all my phone when I use it as the monitor without any problems.  My question is; what features am I giving up if I roll back the moverioglasses to 4.1.15?
Thanks, ~ Bill
2018-4-14
Bart1
Does the OTG works with iPhone, DJI Go 4 version 4.3.0 ?
2018-8-24
12
