Mavi Air Crystalsky can't connect
738 11 2018-2-26
windstar3
Can't establish connection between the RC and my brand new CS nor via USB-USB-C cable nor via WiFi connection.
All firmware / software are on the latest.
While using my mobile phone via the short USB cable to the microUSB connector on the RC it enters the device without issues.
Whith the CS it always stops at step 3 "connect the RC and the mobile device" see screenhshots
Any help would be highly appreciated.
2018-2-26
Tommyxx
Flight distance : 33898 ft
Ci provo
Il cavo corto per intenderci quello laterale corto non deve essere inserito se usi la porta usb sotto!
2018-2-26
Swedrone
Flight distance : 11223586 ft
Sweden
Have you tried to connect it to another device?
2018-2-26
windstar3
Swedrone Posted at 2018-2-26 12:15
what to what device?
2018-2-26
Wachtberger
Flight distance : 261509 ft
Tommyxx Posted at 2018-2-26 12:11
Ci provo
Tu sei un pomodoro... ;-)  He hasn't connected any other cable. Even WiFi connection doesn't work apparently, we had a long chat via PM tonight.
2018-2-26
Wachtberger
Seeing your screenshots I am wondering if you have ever tried to simply skip this setup menu? Just push on the "X" in the upper right corner and see what happens then.
2018-2-26
windstar3
Wachtberger Posted at 2018-2-26 12:30
Is not possible to connect when trying to skip. Pressing the X just brings You back to the main screen
2018-2-26
windstar3
But in the meanwhile after taking teh battery out of the CS and rebooting twice and switching the RC also twice off and on connection was finally established.
2018-2-26
Wachtberger
windstar3 Posted at 2018-2-26 13:00
[view_image]
[view_image]
Ah ok, this changes everything. The issue was the connection between your RC and the MA. I had understood that you did not manage to connect your CS with the RC. Glad that all is solved now :-)
2018-2-26
lannes
Flight distance : 4465 ft
when the AC, RC and DJI Go4 are on sometimes I find that I need to restart the controller to get the CS to recognise the connection in the app
It's something to do with the order of turning things on, I suspect the DJI Go4 needs to be first followed by the AC and the RC
2018-2-26
DJI Thor
Flight distance : 13602 ft
[view_image]
[view_image]
Good to know that you got it worked at the end. Please feel free to let us know if there is anything else we can do, we are glad to help.
2018-2-26
windstar3
THX, will keep You updated if it happens again.
2018-2-27
